Results 1 to 2 of 2
Thread: Transmission help
    Aug 2022
    Albany
    E60
    Transmission help
    I am very familiar with these cars but this issue is racking my head.
    I'm working on a e60 LCI that had obvious tranny issues. Had a hard code for solenoid 3 that left the car unable to go into gear...IT DID NOT POP BACK INTO P, it stood in gear....whichever gear you chose, D, or N, R, whatever..
    So I order all new solenoids from ZF, new pan filter, sealing sleeves, bridge seal, plug adapter, lifeguard 6, and the very rarely overlooked foam strip seal.
    I dropped v body, cleaned contacts, changed noids. Seals, etc. The bridge seal was bad although I seen worse. I reassemble, and yes...the lever was aligned correctly. I filled CORRECTLY as I've done many times.
    Now when I start, and reset adaptations with my scanner, car does same thing. I can feel like the tranny goes into gear but seems like it's stuck in park.
    I dropped pan again, removed v body, rechecked everything, made sure plug adapter was in far enough, clean pins on both harness side and mechatronics. No bent or corroded pins. And still same thing.
    I used scanner to confirm gear selector goes into all gears and it does. No tranny codes. Gws codes. The hard code for noid 3 is in fact gone but it does not drive. Cable is correctly spaced on side. I removed cooler line to confirm fluid pressure and it exists.
    Please help fellow genius people.
    Nov 2022
    Croatia
    E61 LCI 525D
    Maybe wiggle shifter like these guys did can help
    https://youtu.be/LbFxsj_LOb4
  1. 87 325IS transmission HELP
    By racerx944 in forum 1983 - 1991 (E30)
    Last Post: 12-13-2003, 10:28 PM
  2. Transmission HELP Needed!
    By maz in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-20-2003, 01:17 PM
  3. Color and Transmission help!!!
    By AzN_M5 in forum Southwestern - US
    Last Post: 02-07-2003, 01:50 AM
  4. Color and Transmission Help!!!
    By AzN_M5 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-05-2003, 10:00 PM
  5. Wheelspin? Bad Transmission? Help!
    By DJ_Vyb in forum 1992 - 1999 M3 (E36)
    Last Post: 06-28-2001, 02:55 PM
