Results 1 to 9 of 9
Thread: C Pillar Secret?
    radlaw's Avatar
    radlaw is offline SoCalEights Member BMW CCA Member
    Feb 2010
    Poway (San Diego), CA USA
    1995 BMW 840Ci
    Question C Pillar Secret?
    What is the secret of putting the C pillar cover in place? I think the passenger side is in; at least it looks like it. But the driver side one is driving me crazy. I've been trying for 3 days to do it. Either the front clips get in place with the rear clips not inserted or rear clips in place with front sticking out. There's got to be a easy way that one or some of you found. What is it?
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by radlaw View Post
    Remove rear parcel shelve, I found it makes it easier. Bend the pillar slightly and insert rear pins, then work to the front.
    Not an easy job by any means
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Recycled German Plastic
    Mine are held in with Magnets epoxied to the back. Clips are fragile and old, good luck
    radlaw's Avatar
    Feb 2010
    1995 BMW 840Ci
    Quote Originally Posted by dragon850 View Post
    Thank you. That's what I was afraid of and wanted to stay away from removing the rear parcel shelve.
    Jan 2012
    New Zealand
    1996 BMW 840Ci
    Quote Originally Posted by rjjablo View Post
    Keen to know more about this fix - i.e. what magnets were used, type of epoxy and where on the trim did you glue them. Mine are just hanging on so this sounds like a good solution! Cheers.
    Aug 2019
    Tujunga, CA 91042
    850CI740Lsezd750L95sezd
    If it were easy everyone would be doing it. (neodymium)
    Oct 2008
    Mt. Dora, Florida
    CSi#18, Tesla S85
    Look at your tabs BEFORE you try to place the C pillars. The direction you place is not necessarily the direction you think it would be. Trial place them a couple of times WITHOUT pressing it in. This way you understand the direction you push in the tabs. This is why most tabs are broken, because the pillar is not pressed into the retaining clips the correct orientation.
    CSi #18 - Car & Driver Magazine 1994 actual test car
    -- Hellrot/Black-Gray (1 of 1 NA CSi color combination)
    BMWCCA E31 Chapter International Clubs Liaison
    North America Representative, 8er.or Board of Directors
    Sep 2019
    Los Angeles
    1995 BMW 840CI, 2019 X5
    Quote Originally Posted by Treone View Post
    Was thinking of something like this for a pillar. More info?
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Magnets
    I used some 5 minute epoxy mixed with microballons for volume. Got some cheap and strong rare earth magnets.
    Picture is not of the final position of some of the magnets. I had to guess as to depth and then cut and realign them if they did not work. You want them to be flat with the metal structure for max grip.
    Crude but they stay on with the windows down. IMG_20201126_074813_9.jpgIMG_20201126_074826_1.jpg
  1. Secret Thread!!!
    By ///MINI in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-06-2001, 11:39 PM
  2. FINALLY! *PICS* of my A-Pillar Gauges!
    By Seedster in forum 1991 - 1999 (E36)
    Last Post: 08-15-2001, 03:13 AM
  3. *PICS* of my A-Pillar Gauges
    By Seedster in forum 1992 - 1999 M3 (E36)
    Last Post: 08-14-2001, 06:46 AM
  4. Who carries A pillar gauge pods?
    By Logik in forum 1991 - 1999 (E36)
    Last Post: 08-09-2001, 02:02 AM
  5. BMW's Secret M316is
    By ICWIG in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-08-2001, 02:51 PM
