Results 1 to 2 of 2
Thread: solution for stripped valve cover studs?
    Feb 2016
    Brooklyn, NY
    1995 840Ci, 2013 X5
    I have an 840 with an M62 engine and I've managed to strip the hole for one of the valve cover studs in a cam bearing cap. Rookie error, I know, but it didn't take full torque because of someone else's over-exuberance. I pulled the cam bearing cap and a helicoil is a no-go because it would interfere with an oil passage. According to BMW, the cam bearings are machined with the engine and are not sold separately. Anecdotally, plenty of bearing caps have been replaced, so perhaps this is just German over-engineering. Anyone figured out how to fix a stripped cam bearing cap? Has anyone tried cutting new threads? Or am I off to the local junkyard?
    Brett
    San Ramon, CA
    850Ci, M5, Model-S P85D
  1. Valve Cover Stud Stripped
    By ProfFinesser in forum 1991 - 1999 (E36)
    Last Post: 02-21-2021, 09:42 AM
  2. Stripped Valve Cover studs or Holes - What to Fo?
    By peter540 in forum 1996 - 2003 (E39)
    Last Post: 01-21-2021, 09:23 PM
  3. Stripped Valve Cover Stud or Stud Hole
    Last Post: 06-10-2015, 04:34 PM
  4. Valve Cover Stud Broke
    By BimmerChuck in forum 1991 - 1999 (E36)
    Last Post: 03-13-2006, 10:54 PM
  5. Stripping valve cover
    By jmargo in forum 1992 - 1999 M3 (E36)
    Last Post: 10-11-2003, 10:38 AM
