Just wanted to see if I could get this diagnosed somehow.
Transmission had a delay when shifting into drive and reverse. After shifting into “second” the trans drives fine there and after.
When shifting into reverse and first, the rpm’s raise then drop when it finally engages after a few seconds. Shifting into drive being slower than reverse, and sometimes disengages after braking.
https://share.icloud.com/photos/07fe...nHVsconNKCvG2g
Here is a link to a video of me shifting the car.
Do a drain and fill, research on how to do it properly.
Did a drain and fill. Car runs minty again. Thank you all!
