Decided to make an account and post it here as I was getting sick of the uninitiated wasting my time on Facebook marketplace.
I am selling my 09 335xi. Car is a 6MT tasman green metallic coupe, and is likely a 1 of 1 for that spec.optioned with heated seats and steering wheel etc. Heavily modified and extensively maintained (list below)
Located in CT
•09 335xi 11/09 prod date
•tasman green metallic e92 manual (1 of 1 spec)
•35k on motor all gaskets done(150 on shell)
•pure600 turbos
•index 12s, NGK95770, Delphi coils, HPFP <2k miles
•triple LPFP w/Hobbs Switch
•21 row oil cooler to OEM location w/VTTO block off delete
•X-Clutch twin disk <2500 miles
•Bilstein struts & Eibach springs
•Port injection w/injectors & available nitrous ports on custom “misfire race” intake manifold
•AIC 6 harness
•Snow Performance WMI
•Catless DP, Tial BOV, DCI, 5” stepped intercooler
•Braided oil lines & oil catch can
•upgraded fuel pressure regulator
•Upgraded sway bar w/ new bushings & end links
•***** 7” android head unit running MHD & XDelete
•Custom tuned by Shoup on 93
•Enkei Raijin 18x8.5 squared
•New motor mounts
•Transfer case, diff, diff seals, transmission all recently serviced
•New front axle
•New valve cover & gasket
•New OFHG
•New water pump + thermostat
•New radiator + rad hoses + o rings
Flaws: one headlight bulb is out, some minor damage on rear bumper from a shopping cart, little scratches here and there, bit of curb rash on wheels, thats it it is mechanically very sound
I have a bunch of N54 parts laying around (backup transfer case, backup radiator etc) that I could throw in at the right price.
Text me for more info/with more questions/to make an offer/to set up a time to see the car at (860)seven-1-nine-three-064
Thanks for your time
Welcome to the forum! One of the rules of the classified section is that you must post a price. If you've got a link to some pictures that might help as well. Sounds like a beast!
