97 328 sedan. Going to buy the Garagistic seat adapters for my new OMP seat with seat mount brackets and I know I can get a bracket from VAC that mounts to the adapter so I can bolt the receptacle to the adapter on the inside by the trans tunnel, but what do I do to bolt the little black single bolt bracket at the end of the seat belt strap to the seat adapter on the outside? Sedans don’t bolt to the little rod on the chassis. They originally bolt to the seat.
Mike
1997 328i Sport, 5 speed
2013 X5
I can’t quite picture that setup. Do you have a pic?
Mike
2013 X5
I have installed a bolt in cage and 6 point belts so I do not route the factory belt through my seat anymore, hopefully the pictures help;
The end of the seat belt that bolts to the stock seat needs to route from the top of the B pillar down to the inside of the seat then out through the hole to the lower B pillar. If you go over the seat and not through the hole, then cannot get the belt to hold you securely in the seat.
After you route the seat belt from the inside of the seat towards the B pillar, you bolt the end through the same bolt that holds the seat belt retractor to the B pillar.
Ahhh! I see. Brilliant! Thanks.
Mike
2013 X5
