Results 1 to 4 of 4
Thread: Using normal sized injectors on an M43 engine
    Feb 2019
    Yavne, Merkaz, Israel
    1998 BMW E36 318i 1.8L
    Hello everyone, been lurking around for a while and this is my first post.
    Recently I was doing some work on my E36 M43 engine, mostly general maintenance, cleaning the sensors and starting work on the fuel rail. I have the vehicle for about 4 years, and from things I've read and saw, my engine falls in the small category of BMW engines that used a smaller sized injectors, and finding a replacement is pretty tough.
    I remember seeing spacers that raise the whole fuel rail a notch, in order to allow the standard sized injectors to be used. My question lies here, on which injector types should I use with my M43B18 engine, and if there is an aftermarket solution available right now, or should I just machine my own spacers?
    Any more tips would be more than welcome.
    Jun 2010
    NY
    1997 328i
    Rockauto has them, they are remanufactured.
    Have you ever used injector cleaner? They do work, try 3 bottles over 3 tanks, use a different brand each time.
    Feb 2019
    Quote Originally Posted by Eric93se View Post
    DEF was accidentally used from the pump, figured it would be easier to install new injectors than doing an overall on the old ones, they're 20+ yrs already.
    Jun 2010
    NY
    1997 328i
    Diesel fluid?
    I doubt your injectors are ruined. Obviously get all the old fluid out and run injector cleaner over 3 tanks.
  1. What size injector does a 95 540i use?
    By Vonbimmer in forum 1988 - 1996 (E34)
    Last Post: 06-15-2023, 07:59 PM
  2. M43 Engine never reaches normal running temperature
    By vaska85 in forum 1991 - 1999 (E36)
    Last Post: 01-23-2012, 04:36 AM
  3. using stock s50 injectors on a ond1 s52 engine!
    By farzad97m3 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-20-2007, 11:15 PM
  4. What size injectors are in the BMW 1.9?
    By J10B in forum Forced Induction
    Last Post: 01-14-2003, 08:46 AM
  5. NE1 use multipoint fuel injectors from 5-er to M4x or M5x ?
    By DKBMW318 in forum 1991 - 1999 (E36)
    Last Post: 03-13-2001, 12:16 AM
