Results 1 to 6 of 6
Thread: NCS expert COAPI-2000
    Aug 2022
    Slovenia
    E36 e46 e61 e91 f11
    Hello please help me i have tried everything but i always get the following error:
    FA-Fehler COAPI-2000: Fehler in EDIABAS oder in SG-Beschreibungsdatei
    BIP-0001: Zu langer Job-Parameter oder String-Register-Zugriff
    CAS COAPI-2000: Fehler in EDIABAS oder in SG-Beschreibungsdatei
    FA_READ COAPI-2000: Fehler in EDIABAS oder in SG-Beschreibungsdatei
    FA_READ: A_E65CAS
    It reads my VIN in FG correctly but adds another number 7 next to it. INPA works fine.
    I would really appriciate any help!
    Jul 2004
    Houston, TX
    36 Cylinders
    I will assume this is for an E65?
    You probably need to update your NCS Expert daten files for that chassis.
    The VIN is fine, as the last digit is a calculated checksum.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Aug 2022
    Slovenia
    E36 e46 e61 e91 f11
    I tried several daten files but nothing works… no it is for e61 (e60). Do you recommend any specific daten files? I am new to coding.
    Jul 2004
    Houston, TX
    36 Cylinders
    Does it do the same when you try to get the base coding from the other module, LCM (or whatever it is on E61) instead of CAS?
    -Abel
    Aug 2022
    Slovenia
    E36 e46 e61 e91 f11
    If i choose LMA, error pops up: following feature is invalid for Fa: $528
    Jul 2004
    Houston, TX
    36 Cylinders
    Oh ya, your daten is old then
    -Abel
  1. NCS expert COAPI 1000 error, without solution!
    By daemonfool1 in forum Diagnostic Software
    Last Post: 11-25-2019, 04:49 AM
  2. NCS Expert Coding Issue (COAPI-2041)
    By phuksi in forum Diagnostic Software
    Last Post: 10-16-2019, 04:49 PM
  3. NCS expert, Inpa, Programming? 530D 2000 Touring
    By lordhobos in forum E39 Touring / Wagon
    Last Post: 10-09-2018, 12:05 PM
  4. NCS Expert Error COAPI-2064 (E39)
    By erosorama in forum Diagnostic Software
    Last Post: 01-04-2015, 04:10 PM
  5. Help with NCS Expert - COAPI - 1000 error
    By redbull325is in forum Diagnostic Software
    Last Post: 01-14-2013, 05:58 PM
