Results 1 to 10 of 10
Thread: Manual conversion for convertible top
    Cave Creek, AZ
    1993 850ci 2001 M5 / Z3M
    Has anyone successfully removed the hydraulic mechanism and converted the top to manual?
    Regards,
    Brian
    Cave Creek, AZ
    Oct 2012
    Victoria BC Canada
    2004 Z4, 1700 Nomad MC
    Pull the hydraulic release and turn it 1/4 turn and it is in “manual” mode….
    May 2017
    Georgia
    2003 Z4 2.5
    My hydraulic hinges messed up after I moved my motor. All the fluid leaks out when using the motor, so now it's manual until I remove the top and have the hinges rebuilt.
    Cave Creek, AZ
    My plan was to remove the hydraulic system completely and add the gas pressurized spring
    https://www.ecstuning.com/b-genuine-...i/54317111155/
    This is the part found on the manual top cars, #13 shown here:
    https://www.realoem.com/bmw/enUS/sho...diagId=54_0312
    I did this on my Z3m, and love the simplicity and ease of use - different part of course on the z3.
    Regards,
    Brian
    Cave Creek, AZ
    Sep 2018
    Mechanicsburg, PA USA
    2003 2.5 BMW Z4
    I'm guessing you would still retain the electric release /lock motor at the windshield frame to release the top when lowering and later to lock the top when closing. These springs would cut the weight when lowering the top and perhaps more importantly when bring the roof up for closing.
    1st, I hope this works. Please take pic's and when your done, share your results and pic's on this forum.
    You know, years ago when I initially read about people in Germany pulling the roof motor thru the trunk I considered it to be impossible ......until I had no choice but to used the trunk method myself.
    Cave Creek, AZ
    JAS1169 - correct, electric release for the lock and unlock portion of the operation. I will take pics and report back!
    Regards,
    Brian
    Cave Creek, AZ
    Cave Creek, AZ
    Reporting back. New pump assembly was relocated to the trunk and out of harm's way in the drain, then rebuilt hydraulic hinges were installed. Top is now working again.
    Regards,
    Brian
    Cave Creek, AZ
    May 2017
    Georgia
    2003 Z4 2.5
    Well, I've removed my top,and removed the hydraulic cylinders to be sent off to Top Hydraulics to be repaired. I'd planned on using my top as a manual but was given the repair as a Christmas present. I hope the reinstall is easier than the removal.
    Cave Creek, AZ
    I used Top Hydraulics as well, highly recommended!
    Regards,
    Brian
    Cave Creek, AZ
    Tallahassee
    1998 Z3 M Roadster.
    Quote Originally Posted by bdiefAZ View Post
    Same here for 2 Z3s.
    Great service.
  1. Replies: 16
    Last Post: 04-17-2019, 08:11 AM
  2. Replies: 6
    Last Post: 01-03-2017, 05:19 PM
  3. Power to Manual Convertible Top Conversion: Anyone Done It?
    By JAMMArob in forum 1983 - 1991 (E30)
    Last Post: 04-27-2011, 11:36 AM
  4. automatic to manual convertible top conversion?
    By laserdude in forum 1991 - 1999 (E36)
    Last Post: 11-20-2006, 02:37 PM
  5. manual to auto convertible top
    By banger in forum 1999 - 2006 (E46)
    Last Post: 10-29-2004, 11:09 PM
