Results 1 to 4 of 4
Thread: BMw E34 blower resistor
    Jul 2020
    Lebanon
    1989 BMW E34 525i m20b25
    Hello everyone
    My e34 fan speed are not all working. When it's on 2 and 4 its always working, on 3 i should tap on the switch and it works and 1 it barely work. My question is: is the problem the resistor or the fan switch? If anyone can help thank you
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    blower speed problem is usually a problem of the resistor or the sword, depends what is installed in your car
    resistors by maker type http://bmwfans.info/parts-catalog/E3...ts_for_heater/
    sword / limit switch http://bmwfans.info/parts-catalog/E3..._limit_switch/
    the speed of the fan blower is controlled through two types of setups on the BMW E34: the final stage unit (older E34s) also called "the sword" because of its look or the blower series resistance.
    Failure syndromes:
    • Fan blower not working on position 1,2 or 3,
    • Fan blowing in full blast whatever the position of the knob.
    http://www.bmwe34.net/E34main/Mainte...ical/Sword.htm
    Jul 2020
    Lebanon
    Can the problem be the fan switch? Once i switched another climate module and only the 3 didn't work and another one the 1 and 2. And when i tap on the current fan switch or when i press it in while changing from 2 to 3 it works. Can this be from the switch?
    Mar 2008
    westlake village, ca
    1995 540i; 2008 550i
    Quote Originally Posted by Kamz e34 View Post
    Could be the switch. Mine used to work on all the lower settings 1-3 but turning it to 4 didn't have any effect, still would blow at #3 level. I tried changing out the blower resistor but didn't make a difference.
    So I removed the switch and cleaned with electrical contact cleaner. When I reassembled, voila had full power fan on #4 again!! Unfortunately over time its now gone back to it's old behavior but intermittently. So sometimes I get full power, most of the time it maxes out at 3. Haven't bothered to take it apart to clean again--it's kind of a pain--but if I do I think I'll try a stronger cleaner which may do the trick!
  1. BMW E34 blower fan
    By Kamz e34 in forum 1988 - 1996 (E34)
    Last Post: 06-15-2022, 01:33 AM
  2. E34 Genuine BMW New Old Stock E32/E34 Blower Motor 64111388175
    By rbelton in forum E34 Classifieds (closing soon)
    Last Post: 02-26-2022, 01:03 PM
  3. Brand new BMW e34 blower motor - SOLD
    By marks525 in forum Interior Lighting & Body Parts
    Last Post: 06-02-2015, 09:33 PM
  4. E34 E34 blower resistor
    By cascios in forum BMW Parts Wanted
    Last Post: 11-22-2012, 11:54 AM
  5. WTB e34 blower resistor...asap please....
    By somerandomdude in forum BMW Parts Wanted
    Last Post: 10-21-2008, 01:02 AM
