Results 1 to 3 of 3
Thread: 1983 E21 320i hydraulic clutch system assembled and bled on bench - any thoughts?
    Jul 2017
    San Francisco, CA
    1983 320i
    Looking for opinions and/or experiences on pulling the clutch master cylinder, line and slave cylinder to bench bleed as an assembled unit on the bench and reinstalling without needing to disassemble the system.
    I understand some will say leave it in and bleed it, your bleeding it wrong, bleed it this way, that way and so on. I appreciate the intentions but I'm looking for confirmation that I can have the assembled system on the bench and bleed it as a whole, successfully and put it back in the vehicle, assembled.
    I do see that potentially getting the clutch master cylinder back into place may be difficult or not possible with the hydraulic line, etc. attached. This is the kind of information I am seeking. What to expect, what to avoid, what not to do or how did you do it.
    Thank you for your interest and responses in advance.
    Ethan
    Aug 2001
    NC
    E30M3,318is,318i,E21320
    Quote Originally Posted by fredskidoo View Post
    Ethan
    Racers are lazy, so we cut a huge hole for easy access to the clutch master. Install everything and leave the clutch slave cylinder off the trans but held vertical where the push rod faces the floor and bleeder is up highest point. Crack the bleeder and wait for fluid. Don't touch any pedal. Once fluid dribbles can push the rod of the slave by hand a bit to ensure no air bubbles but wouldn't push it all the way. Once a nice stream of fluid close and install on transmission. Don't get fluid in your beer.
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    When I have changed mine out, I bleed the whole system out with the one man bleeding system with pressure bleeder, back of car 1st, then front and then clutch slave last, I also use DOT 4 brake fluid, it does not take long. 15-20 psi will last the whole job.
    Randy
  1. E21 FS: 1983 E21 320i Part out Baltic Blue
    By SenorTaylor in forum Whole Parts Cars
    Last Post: 11-28-2021, 12:29 AM
  2. Replies: 27
    Last Post: 03-19-2008, 11:24 AM
  3. Parting out 1983 E21 320is
    By bimmer83is in forum BMW Parts For Sale
    Last Post: 05-07-2006, 11:31 PM
  4. 1983 E21 320i.........what's it worth
    By M3inNC in forum 1975 - 1983 (E21)
    Last Post: 01-05-2006, 02:13 PM
  5. help me understand the hydraulic clutch system!
    By ReVsHoT in forum 1991 - 1999 (E36)
    Last Post: 01-21-2005, 02:31 PM
