My dad is in town, his car, leaving in a few days. Noise started on the trip and then got worse on their drive up.
It's worst when accelerating between 15-25 mph. Seems worst in 1st gear and gets progressively quieter and less noticeable, even if you're in 3rd at the same speeds it's much less noticeable. Even hard acceleration at higher speeds doesn't cause it. It's a loud, fast clunking.
Turning doesn't seem to effect it. Seems to come either from the transmission tunnel, driveshaft, differential, rear end, something like that.
Sorta sounds like a miss, but the only code is a pending P0440 that I think is probably unrelated. It also doesn't happen at high speed, low rpm, high loading when a miss should be worst. And doesn't sound like quite the right location although sounds in cars travel all over.
Jacked it up and the CV joints at the rear look fine, no play, no grease leaking.
The driveshaft rubber joints were replaced but not recently and we haven't checked them yet.
It's strong enough that you can feel it in your butt and your hand resting on the console for example.
Any ideas? My dad is a really, really good mechanic and I'm not a terrible one and we're kinda stumped and running out of time.
Csb?
Seems promising. If we get it up on ramps or jacks is it pretty obvious to check?
They ended up doing the CSB and went ahead and did the rubber joint at the front of the driveshaft because why not while you've got it apart.
It fixed it. Not sure which it was for sure.
Current stable:
2002 525i (Daily Driver)
1994 SN95 Mustang 'Vert (The Bumblebee)
2001 325i Convertible (Beach cruiser project)
