Results 1 to 14 of 14
Thread: Aux fan question
    Vermont
    81 320i, 98 318ti
    Aux fan question
    Does anyone know if all 80-83 U.S. e21's came with the electric aux fan in front of the radiator? Or it was part of A/C system and was added when the A/C was installed by the dealer?
    Does anyone have a working fan with all the hardware?
    Thanks,
    Max
    Feb 2002
    Austin, TX
    G05, F15, E46, E21 (x2)
    I have a heavy a$$ working OEM fan and brackets from a/c delete car. PM me.
    If not worried about originality, light SPAL fan is better, more efficient, solution IMHO.
    Sep 2011
    Vacaville,CA
    1987 BMW 535iS
    The auxiliary fan is part of the a/c system.
    Vermont
    81 320i, 98 318ti
    Thank you for clarification. It is hard to find a 40 year old information, only a few folks know what these cars used to have before dealers added the options. So no fan on non AC car then.
    Aug 2011
    Ontario, Canada
    1980 E21 M10
    Quote Originally Posted by ascot View Post
    This is not correct. I have the aux fan and my car did not come with A/C from the factory.
    Feb 2002
    Austin, TX
    Ascot: Not true. As said, my non-a/c car has the factory fan
    Vermont
    81 320i, 98 318ti
    Thank you everyone- I was looking at the wiring diagrams, parts catalog and A/C retrofit instructions from BEHR and it seems like the aux fan was installed on all U.S. spec cars regardless and was not optional (where things like fog lights were).
    May 2018
    LA, CA
    1982 BMW 320is
    It would be interesting to see how the aux fans are attached on the non A/C fitted cars. Based on what I have seen, the fans are attached to the serpentine condensers.
    Vermont
    81 320i, 98 318ti
    I was just looking at the attachment points and and the fan is attached to the sides of radiator support (vertical) using L shaped brackets. It goes in the front of the cooling radiator. I believe if there is a condenser for A/C, condenser is attached to the radiator support by itself, it goes between the radiator and the electric fan. Not sure how exactly the condenser is normally mounted.
    Feb 2002
    Austin, TX
    Here is a photo of the aux fan and brackets for a non-a/c car...
    Here is what I did when adding a/c...
    Aug 2016
    Pennsylvania
    e12, e21, e36
    I removed my original dead fan years ago and modified the mounting brackets and made a few custom pieces to install a high volume Spal fan. Less power draw and I believe it moves much more air.
    waltb
    '82 320i
    Vermont
    81 320i, 98 318ti
    Thanks for the information. I am trying to keep it original and the car has no A/C and missing the fan (it was removed in the past), so that extra fan does not need to be that efficient. I got the original fan from DavidF, so I will just put it in. Wiring is all there, all e21's must have come prewired for it. At least U.S. models.
    Jan 2006
    Milwaukee
    '81 320i, '05 Scion
    Does this fan do anything if you don't have A/C? Mine has it, but the rest of the A/C hardware was removed years ago. I was thinking about pulling this out too. Unless it is actually for the radiator.
    My Car Blog:
    http://motoluvr.blogspot.com
    My current cars:
    '16 Fiat 500e (electric)
    '92 Honda accord
    '05 Scion xB
    '81 BMW 320i
    '12 Toyota Prius
    Feb 2002
    Austin, TX
    USA cars got the fan regardless of a/c. It is controlled by a temp sensor in the radiator and will turn on if the coolant gets too hot…think 100+ days. I would keep it.
    With a/c cars, the fan is controlled either by coolant temperature or when a/c is turned on. There is a diode in the circuit of a/c cars the prevents the coolant temp circuit from engaging the a/c compressor. The replaceable diode is located behind the left headlight. If no a/c car, there is just an unused connector behind the headlight.
    Quote Originally Posted by typhoon320i View Post
  1. Aux Fan Question
    By samhell in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-29-2005, 08:46 PM
  2. AUX fan question
    By nateb in forum 1983 - 1991 (E30)
    Last Post: 07-24-2004, 11:23 PM
  3. aux fan question
    By Chugger in forum 1992 - 1999 M3 (E36)
    Last Post: 08-04-2003, 04:33 PM
  4. Aux fan question??
    By stiff///M&02 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-17-2003, 05:40 PM
  5. Aux fan question...
    By BMWFAN in forum 1991 - 1999 (E36)
    Last Post: 09-21-2002, 03:08 PM
