Results 1 to 8 of 8
Thread: Tailgate glass inop
    Nov 2007
    Justin Texas
    2003 525it 2003 X5 4.6is
    Tailgate glass inop
    Everything else works fine. Can’t pop the glass to open.
    Looked up fuses, didn’t see tailgate/glass on the menu.
    The hatch pops open just fine, and closes fine.
    Any tips where to start?
    I will always own a BMW.
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Check the wires in the hinge area. You have to remove the plastic covers, at this age, they get frayed up in there. If they got frayed and exposed to the environment, the copper will have gotten the corrosion in the exposed area, but the creeping copper black death may have gone both directions from the exposed area. If that happened, you have to expose the copper by stripping off the shielding until the copper looks like copper, solder new wire in there to complete the wire, use the same gauge, can’t remember what it was, but probably 18 gauge, over it up with heat shrink. In the covered hinge area, you have to make the repair as clean and size wise, match the original wires as much as possible, the covers will give you a hard time if the wire repair is too large in diameter.
    Nov 2007
    Justin Texas
    Works fine this AM. it’s a BMW, always interesting.
    Nov 2007
    Justin Texas
    Still not opening. I can hear the electric motor come in. But it’s not like the lower motor.
    Can have a weak motor? Wiring all looks good. Just wimpy wimpy hatch motor.
    Not enough to pop the glass. More of an irritating problem. I rarely use the glass hatch.
    But would like it to operate.
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    Motor? For the glass? I thought it was a solenoid. The door base has a motor.
    Feb 2014
    Alexandria, VA
    Yep, it’s a solenoid.
    Nov 2007
    Justin Texas
    Ok, can I have a weak solenoid?
    Nov 2007
    Justin Texas
    Fixed it
    Bought a replacement used solenoid hatch mechanism. I just swapped out the pansi solenoid with my new one. Working perfectly now.
  1. E91 320D CCC & tailgate glass micro switch problems
    By FoxKhan in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-08-2020, 07:24 PM
  2. Cannot get Tailgate glass open
    By xcastaway in forum 1988 - 1996 (E34)
    Last Post: 05-20-2018, 07:15 PM
  3. Replies: 2
    Last Post: 12-06-2017, 02:43 PM
  4. My tailgate glass wont open on my Touring (Wagon)
    By 320de46m47 in forum 1999 - 2006 (E46)
    Last Post: 03-06-2008, 01:01 PM
  5. Tailgate glass window opens unexpectedly!
    By AndyG in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-20-2007, 08:44 AM
