FCP Euro pointed out the error of my ways when pouring oil: https://youtu.be/dEAx-I3f82w
I never thought of that, although I may have accidentally done better holding the container sideways a few times.
Claude Berman, 96 Z3 Production Date 2/96 BMW CCA# 581686
The only good is knowledge and the only evil is ignorance. Socrates, 469–399 B.C.E
I guess us old dogs can learn new tricks!
You don't even need to worry about the direction if you use the better method, which is just squeezing the container. Even faster.
Nathan in Denver
2000 Z3 M Titanium Silver / Imola Red+Black Nappa
2011 328i E92 Space Gray Metallic / Leder Dakota+Oyster
Since 1987 12 euros / 2 kdms / 2 jdms
- Zach
I learned this trick a few years ago but I still start pouring the "wrong" way probably 1 out of 4 times then I remember and flip the jug around lol
PRICE CUT on ALL FABRICS
I'll take glugging over missing the mark. Missing the mark is always on my mind when I consider the "right way".
Nathan in Denver
Maybe I'm just getting really old, but doesn't anyone else just use a funnel? I have dedicated ones for engine oil, trans fluid, coolant, and waste fluids. I for one would not want to try pouring oil from a 5-qt jug directly into the engine.
Kelvin
Most of you guys are probably too young to remember "Dear Abby", a newspaper advice column. On this topic, she had so many opinion letters coming in, on both sides, she finally said "Stop the letters".
The "correct" position is unprovable, so I will simply decide what is correct: it should be on the front.
Loose side to the front! My fiance put a new roll in the other way last week and I took a picture and messaged her telling her it was absolutely inhumane. Eek
Using a funnel does not mean you can't use the right pouring method. I usually use a funnel, unless im just topping up. However if not using a funnel one should definitely use the correct ("upside down") pouring method because then it pours in the same location with predictable laminar flow
Nathan in Denver
