Results 1 to 10 of 10
Thread: M30b35 low engine vaccum. Suspecting valves are too tight
    Sep 2020
    Palatine, IL, USA
    1990 BMW 535i
    I知 trying to chase down a rough idle on my car. I checked for vaccum leaks (none found) and a vaccum gauge says 12-13 inches of Mercury in park at idle and 10 in drive. I had the headgasket and head redone and I知 suspecting the valve lash is off. When I知 driving car runs great minus a small hesitation on takeoff. Before I did the headgasket the car ran smooth as glass. Any ideas? I got 201,000 on it
    Denver, CO
    Only time I have experienced a stumble coming off idle, was after installing a parts store distributor cap. The damn thing had a hairline crack in the plastic housing, and would arc externally periodically.
    The Bosch replacement (and its Bosch replacement) have been flawless in their operation.
    I could hear the arc much more readily than I could see it.
    Maybe your dizzy cap was dropped and cracked?
    Sep 2020
    Palatine, IL, USA
    1990 BMW 535i
    Dizzy is new
    Dizzy is new
    Denver, CO
    Mine was too. Hopefully yours is of better quality than that piece of garbage was. I know I will only use OEM parts myself.
    If you suspect valve lash, you could always verify to rule it out. Take a couple hours, but not difficult.
    NW suburban Chicago
    hiss by my window
    Then check the valve lash.
    In my experience they like the looser end of the range. Too tight will cause rough running and in some cases burnt valves.
    Sep 2020
    Palatine, IL, USA
    1990 BMW 535i
    That’s what I’m doing Monday at a shop I don’t feel confident trying it myself
    Sep 2020
    Palatine, IL, USA
    1990 BMW 535i
    Shop did the valve lash yesterday. The engine does tick a little bit which is not a big problem for me but now she runs like a top and it has more power
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by kapicarules View Post
    It is sometimes tough to get it right with older engines having worn lash adjusters. I've found measuring at the cam rather than at the valve stem as is customary makes adjustment easier.
    A tick won't hurt it.
    Curious as to who did the job as I am local to you.
    Even thirty plus years ago a very few engines required this sort of maintenance so sadly it gets neglected more often than not.
    Sep 2020
    Palatine, IL, USA
    1990 BMW 535i
    R&M auto performance auto care in Palatine. It’s located on rand road across the street from the Palatine Walmart on rand road. Their phone number is 847-907-9855. I paid 180 but it depends on what motor you got and how difficult the job is.
    NW suburban Chicago
    hiss by my window
    Thanks, I'm not familiar with them but know the spot.
  1. VF Engineering Race Bypass Valve
    By 5mall5nail5 in forum Forced Induction
    Last Post: 11-26-2005, 02:28 PM
  2. Replies: 5
    Last Post: 08-29-2005, 05:16 PM
  3. supercharged engine vaccum level???
    By Black Mamba in forum Forced Induction
    Last Post: 06-15-2005, 10:23 AM
  4. Engine Tapping.. Replacing valve cover, what to look for?
    By psonio7 in forum 1991 - 1999 (E36)
    Last Post: 01-20-2005, 12:30 AM
  5. Replies: 5
    Last Post: 10-31-2003, 10:31 PM
