Results 1 to 4 of 4
Thread: N62 b44
    Jul 2022
    Macedonia
    Bmw E39 535i
    N62 b44
    Hi , maybe someone convert N62 B44 automatic gearbox to manual or maybe someone know which manual gearbox can fit to N62 b44 ?? Thx in advance..
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    on which car do you want to make the conversion?
    The N62B44 Applications:
    2001-2005 E65/E66 745i/745Li
    2004-2006 E53 X5 4.4i
    2003-2005 E60/E61 545i
    2003-2007 E63/E64 645Ci
    2005-2007 Morgan Aero 8 Series 2 and Series 3
    Jul 2022
    Macedonia
    Bmw E39 535i
    E65 - 2001-2005 745i
    The GS6-53 gearbox used on manual equipped 545, 550, 645 and 650 models will fit the N62 engine. The GS6-53 used on the S65 M3 as well as the ones in the 335i and similar I6 engines will not fit so make sure it's from an N62. You would likely need to custom fabricate a transmission mount (although 5 or 6 series parts *may* work) and shifter carrier as well as shift linkage. You would also need some custom work in the center console as the E65 did not come with a manual in any markets that I am aware of. Not sure where you'd put the shifter since those have a column mounted shifter selector. Driveshaft will likely need to be custom unless 5/6 series parts happen to fit. It will need to be re-coded a little bit as well and that may not be an entirely straightforward task since the E65 never came with a manual. Most likely you'd use E60 or E63/E64 coding, but I am not sure it will play nicely with all the E65 modules when coded like that
  1. N62 B44 Engine cranking but not running, how to solve it
    By Miihkali in forum 2004-2010 (E60,E61)
    Last Post: 09-15-2017, 04:48 AM
  2. N62 b44 catalytic converter please read! Important
    By oliverd642 in forum 2002 - 2008 (E65, E66)
    Last Post: 04-18-2017, 05:45 PM
  3. N62 engine
    By RichChild in forum 1996 - 2003 (E39)
    Last Post: 11-12-2006, 07:37 PM
  4. Dinan E60/E63/E64 545i/645i N62 Throttle Body
    By bmw_e30 in forum BMW Parts For Sale
    Last Post: 09-14-2006, 02:29 PM
  5. n62 745li long block for sale, 22,000 miles!
    By micjester in forum BMW Parts For Sale
    Last Post: 04-24-2006, 05:57 PM
