I have searched the site and have not found my particular problem. I have no air at all coming from the front vents. Just quit yesterday about an hour and a half from home. AC to the seats, rear and defrost works fine. I did have a click/tap/knock type noise come from the area under the front center speaker area about every thirty seconds every so often. Very intermittent. Assuming it is related. Does not matter if I use Max AC or Auto.....no air at all from front vents. Is there a Blend Door or something similar in the console under center speaker that would cause this? Other possibilities? Thanks in advance.
I reckon your blower motor has packed up - same happened to mine after a thorough engine bay pressure wash.
The unit is located under one of the removable plastic panels in the engine bay. It’s quite easy to replace and fairly cheap to buy. Procedure is the same as on the f10 and there’s a few videos on YouTube to help
