Results 1 to 2 of 2
Thread: Generator Fault came on after a burning smell in the engine compartment
    Jul 2022
    Canada
    BMW 750 Li
    Initially had a higher pitched whine in the engine that went away when RPM's went up, took the car for a spin and smelled a burning smell and a little bit of smoke coming up from the engine when I popped the hood, left it for 10 minutes and started it up and had a "Generator Fault!" pop up on the instrument cluster to the below the RPM gauge and a battery image pop up in the center of the display. Car drive's fine, the high pitched wine is gone but the "generator fault" is still illuminated. The car has had a new battery within the last 12 months so is this the alternator that just burned out, while the car battery slowly drains? (hasnt happeneed yet but just wanted to get some feedback if anyone has gone through this with a 2007 750 Li
    Thanks for your time all
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    Very likely that is where you are now. The bearings go, and then you are in failure mode. He won’t run long without the alternator.
  1. HELP: smoke/burning smell coming from engine
    By max2moon17 in forum 1996 - 2003 (E39)
    Last Post: 01-08-2016, 07:22 AM
  2. Burning Smell Coming From Engine
    By RyanP in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-26-2011, 02:21 PM
  3. Burning smell coming from engine compartment
    By jmejia15 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-07-2011, 12:56 PM
  4. Burning smell after high revs
    By mikey36m3 in forum 1991 - 1999 (E36)
    Last Post: 01-25-2006, 02:17 AM
  5. Burning smell after minor accident
    By koolkat1973 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-03-2005, 07:58 AM
