eBMWParts
Results 1 to 2 of 2
Thread: G22: Steering loose/vague on one side
    Jul 2022
    DFW, TX
    2022 BMW M440i Couple
    Hi all,
    I have a 2022 M440i coupe with about 5k miles on it. A couple weeks ago, I hit a pothole and threw it out of alignment. The steering wheel was tilted to the right and, if I held the car straight, it veered to the left. I also noticed that turns to the right felt loose and vague.
    Since then, I had my local dealer do an alignment. Now the steering wheel is centered and it drives straight, but I'm still feeling some slight looseness on right turns. Basically, if I do a hard left turn, the steering feels precise with the normal about of resistance. On a hard right turn, the wheel feels loose and unpredictable. Also, when changing lanes on the highway, it seems like I need to move the wheel more to move right than left. It's not night-and-day, but I definitely notice it (and it's pretty bothersome). Already checked pressure - left and right are within 1 psi of each other.
    I'm taking it back to the dealership tomorrow, but I want to make sure they know where to look. This dealership has a tendency to fix something 90-95% but not 100%. This issue might not be glaringly obvious on a short drive at low speeds, but I definitely feel it on higher-speed situations and windy roads. I'm worried they'll just check the alignment and give it back without checking everything.
    What should I insist on them checking? Any ideas on what specifically might be causing the issue?
    Thank you all!
    Michael
    Jun 2012
    San Antonio, TX
    1995 BMW M3 Coupe
    Sounds like the alignment is still off. Do you still have the alignment sheet from when the repair was done?
  1. steering loose and i need some advice
    By m60b30530i in forum 1988 - 1996 (E34)
    Last Post: 09-29-2008, 07:56 PM
  2. Steering loose on E30--suggestions?
    By Bimiac in forum 1983 - 1991 (E30)
    Last Post: 01-08-2006, 01:00 PM
  3. loose rattle from driver side rear when accelerating
    By mirek in forum 1991 - 1999 (E36)
    Last Post: 08-19-2005, 03:23 AM
  4. Steering loose on the highway
    By OldM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-17-2004, 10:38 AM
