This is the passenger side trim piece by the front window. It seems to be made of glass or porcelain. Anyone know the part and how to replace? Thanks, all!
07 E92
Carefully slip a razor blade underneath. If you have the replacement parts before you remove them you will see how they are attached with adhesive or double sided tape. The part numbers below are from FCP Euro, I am not sure why they are named and priced differently, but they are what I used on my E92.
BMW Cover Column B Right
BMW-51377453300
BMW Window Trim Cover
BMW-51377453299
Thank you, so much, Jeff S!!!
