Results 1 to 11 of 11
Thread: E61 530d -04 K-CAN Line Fault, Windows and Door locks open by themselves
    Jul 2022
    Finland
    E61 530d Touring -04
    Picture of the ISTA Module wood:
    https://i.imgur.com/MzBEj8z.jpeg
    Fault codes:
    S 0180 No communication possible with: Safety module/restraint system 452058 yes
    00A177 CCC-GW: Fan not functioning 452056 No
    00E184 CD / M-ASK / CCC / RAD2 / CHAMP -GW: K-CAN line fault 452056 No
    009E39 PDC: Wire, ultrasonic sensor, front centre left 452056 yes
    00E244 SZM: K-CAN line fault 452056 yes
    00E2C4 CON: K-CAN line fault 470736 yes
    00E444 SMFA: K-CAN line fault 299920 No
    00E484 SMBF: K-CAN line fault 299920 No
    00E504 LM: K-CAN line fault 452056 yes
    00E104 KOMBI: K-CAN line fault 448128 yes
    009322 LM: Reversing light, right, faulty 524280 yes
    00E584 KBM: K-CAN Line fault 452056 yes
    009C77 IHKA: Auxiliary-water pump 452056 yes
    009C78 IHKA: Washer-nozzle heating 452056 yes
    00E704 IHKA: K-CAN line fault 452056 yes
    00E71B Message error (ambient temperature, 0x2CA), receiver integrated
    automatic heating / air conditioning system, transmitter instrument
    panel
    452056 yes
    009C50 IHKA: Rear compartment stratification flap motor 452056 yes
    009C68 IHKA: Ventilation temperature sensor 452056 yes
    S 0172 No communication possible with: B-pillar satellite, left 452058 yes
    S 0059 No communication possible with: Trailer module 452058 yes
    00A3C0 Message error (trailer module), receiver instrument panel, transmitter
    trailer module
    452016 yes
    00A3B3 Message (active roll stabilisation, 0x0BE) faulty, receiver KOMBI,
    transmitter ARS
    452016 yes
    00931B KOMBI: Outside-temperature sensor 451080 yes
    S 0193 No communication possible with: Steering column switch cluster 452058 yes
    S 0187 No communication possible with: Door module 452058 yes
    S 0189 No communication possible with: Door module 452058 yes
    S 0177 No communication possible with: Satellite, vehicle centre 452058 yes
    004C03 Message (cruise control/ACC, 0x194) defective, receiver DDE,
    transmitter ACC / DSC / SZL / LWS
    452056 yes
    004242 DDE: Glow plug, cylinder 4 452056 yes
    004252 DDE: Glow plug, cylinder 5 452056 yes
    004262 DDE: Glow plug, cylinder 6 452056 yes
    00483D DDE: Throttle actuator 452056 yes
    005150 No message from the trailer module, receiver EGS, transmitter AHM 452048 yes
    005E8C Message (trailer, 0x2E4) missing, receiver DSC, transmitter AHM 452056 yes
    S 0195 No communication possible with: Telephone control unit 452058 yes
    00D704 EHC: K-CAN line fault 452056 yes
    00D710 Message error (status, central locking system, 0x2FC), receiver EHC 452056 yes
    005F8E EHC: Ride-level sensor, rear left 452056 yes
    00D904 CAS: K-CAN line fault 452056 yes
    00D9C4 MPM: K-CAN line fault 452056 yes
    00DA04 SHD: K-CAN line fault 452056 yes
    00A3A9 Message (steering column button signal , 0x1EE) faulty, receiver
    KOMBI, transmitter SZL
    452016 yes
    S 0174 No communication possible with: B-pillar satellite, right 452058 yes
    00FFF2 MOSTSYS: MOST ring break -1 unknown
    I've been researching this for many months now and it seems like it's giving me gray hair. K-CAN Line Fault is still on.
    I have used every module of the rear container and the modules of the seats as well. But K-CAN Line Fault does not lose anything.
    What would you do next here?
    Should we ask a Finnish person to look at something with a oscilloscope?
    Jul 2022
    Finland
    [MEDIA=imgur]MzBEj8z[/MEDIA]
    Fault codes:
    panel
    452056 yes
    trailer module
    452016 yes
    transmitter ARS
    452016 yes
    452056 yes
    452016 yes
    Should we ask a Finnish person to look at something with a telescope?
    Jul 2022
    Finland
    Last edited by shogun; 07-12-2022 at 04:35 AM. Reason: duplicated fault codes removed
    Current cars:
    E61 530d -04
    Jul 2022
    Finland
    Last edited by shogun; 07-12-2022 at 04:22 AM. Reason: duplicated fault codes removed
    Current cars:
    E61 530d -04
    Jul 2022
    Finland
    Last edited by shogun; 07-12-2022 at 04:26 AM. Reason: duplicated fault codes removed
    Current cars:
    E61 530d -04
    Jul 2022
    Finland
    E61 530d -04 K-CAN Line Fault.
    Should we ask a Finnish person to look at something with an oscilloscope
    Last edited by shogun; 07-12-2022 at 04:29 AM. Reason: duplicated fault codes removed
    Current cars:
    E61 530d -04
    Jul 2022
    Finland
    E61 530d -04, Windows and Door locks open by themselves
    The doors open from the lock and the windows open about 1-2 times a month by themselves.
    I've been explaining this for 2-3 months now, but I can't find the fault myself.
    There is no fault code coming from this in any way, or at least I didn't notice that there was a fault code.
    Now the help would be very useful.
    Could, for example, the micro-switch of the driver's door lock do that?
    Or as it was said somewhere that the SGM module could solve this problem?
    However, the SGM Module is green in the ISTA module tree
    Current cars:
    E61 530d -04
    Jul 2022
    Finland
    However, the SGM Module is green in the ISTA module tree.
    Before When someone says that they are sure that the button is not pressed at the bottom, then:
    The key has run out of battery. In other words, nothing happens from the button on the key.
    As I explained, I lock the doors from inside the car with the button on the center console and lock the driver's door from the door.
    In addition, I make it a point to bring the key inside and check that the doors are locked when the key is on the table in my room.
    And yet in the morning the doors are unlocked and the windows open
    What could do this problem.?
    Current cars:
    E61 530d -04
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    please do not post your problem multiple times and always in a new thread, I have now merged all of your posts/threads, you have deleted some, just wait till someone posts a reply
    Jul 2022
    Finland
    Quote Originally Posted by t0nniz1 View Post
    Fault codes:
    I do know that there is a problem on the MOST bus side.
    The problem is on whether the TEL/MULF is in place or not.
    The currently installed loop.
    Current cars:
    E61 530d -04
    Jul 2022
    Finland
    K-Line Fault solved
    The problem has been resolved.
    A fault for this K-Line Fault.
    The problem was as unique as in the container HKL and Trailer module
    Guide:
    The easiest way is to find out the K-Line Fault by taking one area at a time, for example in my case I started with the modules in the container.
    I did this myself:
    All modules disconnected.
    I put one module in place and looked to see if the SAME module from the tree goes green.
    If I went green, I went to the next one.
    If it didn't go green, I took it off and moved on to the next one
    Current cars:
    E61 530d -04
  1. no auto roll window when door is open
    By mesallem in forum 1996 - 2003 (E39)
    Last Post: 01-21-2010, 04:51 PM
  2. Power windows and door locks stopped working.
    By JohnSterling in forum 1995 - 2001 (E38)
    Last Post: 09-01-2009, 09:41 AM
  3. Replies: 10
    Last Post: 04-15-2008, 11:33 AM
  4. Power Window/Sunroof/Door Lock Failure
    By DragonSoldier in forum 1991 - 1999 (E36)
    Last Post: 05-25-2007, 01:38 PM
  5. Window and door lock problem... 96 750iL
    By moabxj01 in forum 1995 - 2001 (E38)
    Last Post: 11-13-2004, 03:31 PM
