Page 3 of 3 FirstFirst 123
Results 51 to 57 of 57
Thread: M62tu p0120 p0100
  1. #51
    May 2020
    Phoenix, Arizona
    E39 540i
    One other thing to mention…
    I had an old version of INPA on my computer which worked, and then downloaded the Mike’s Easy BMW tools.
    I couldn’t get it to work. I tried my old INPA, that stopped working too.
    I then deleted my old INPA and the Mike’s downloaded INPA started working.
    You may want to delete your current INPA before you download and install Mike’s INPA.
    Im still not getting the black boxes, but inpa is reading my vin still? I don’t know what the deal is. Do you know how to turn off the light check for the front side lights.?
  2. #52
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Quote Originally Posted by Romanleal99 View Post
    If INPA is reading the VIN it’s communicating with the DME.
    Your connecting to the port under the hood, right?
    Do you have burned out front side light? Replace them and the light check message will go away.
  3. #53
    May 2020
    Phoenix, Arizona
    E39 540i
    Im connecting at obd2 port…
    I have led halos installed, and they get power from the side lights. All my lights work normally
  4. #54
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    Which cable are you using to connect the laptop to the obd2 port under the dashboard ?!
  5. #55
    May 2020
    Phoenix, Arizona
    E39 540i
    Quote Originally Posted by Chedley View Post
    Bimmergeeks k+dcan obd2 cable
  6. #56
    Oct 2017
    Alright. Then I suggest you reinstall "mike's Easy BMW Tools" on a clean Windows laptop.
    That is:
    1. first, remove any and all older versions of inpa, then reboot.
    2. Then download it and install "Mike's Easy BMW tools" zip file, and make sure the usb port on the laptop is configured right (See the many postings on this issue in the main Mike's easy BMW thread-.
    3. Then turn off your anti-virus and internet connection on the laptop, connect it to the car, turn key to position 2, and start up INPA : you should get connect and see those battery and ignition highlighted on...
  7. #57
    Feb 2009
    Arizona
    1998 e36
    Had the same problem, it ended up being corroded pins on the DME. Moisture accumulates in that box causing some of the pins on the DME to corrode.
  1. E39 540i p0120 and p0100
    By Romanleal99 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-10-2022, 04:27 PM
  2. Replies: 42
    Last Post: 09-25-2006, 10:18 PM
  3. ICV cleaning for M62TU
    By NickAD in forum 1996 - 2003 (E39)
    Last Post: 04-08-2006, 10:09 AM
  4. ATTENTION: MODEL(s): E38 (7 Series), E39 (5 series) E53 (X5) and Z8 with the M62TU or
    By wgf1960 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 11-10-2005, 06:26 PM
  5. FS or Trade: ignition coils for M62/M62TU
    By Beej in forum BMW Parts For Sale
    Last Post: 06-28-2005, 10:01 PM
