Long story short: a member of the family hit a pole on the right passenger side of my E60. Took it upon myself to find a used, in good condition door to replace it.
Took all the components including wiring, door panel, etc. from the old door and transferred them to the used door shell I got on eBay. Put it back on the vehicle and now I'm getting the following codes:
- 93DA Deactivation front passenger door module (E60, E61, E63, E64) or satellite A-pillar, left (E65, E66, E67, RR01(
- 93B0 Head airbag, left
- 93E4 Self-test: too few messages
Managed to clear the following codes (I will check again over the weekend if they appear):
- 96CC Open circuit, firing circuit, thorax airbag, front right
- 96CD Control-unit fault
- 96FD Voltage supply: limit value exceeded
I did remove the negative terminal when removing the door panel and attaching the door especially because of the airbag. The one suspicion I have is the wire connected to the airbag is not inserted properly, and the other is a fuse was blown, both of which I plan to check this weekend. Could it be the negative terminal cable?? Replaced that several times in the past lol.
Nonetheless, I was wondering if there are any other suggestions in regards to this issue? I do not see any other codes to suggest something else. Thank you in advance
UPDATE: I got a chance to open the door panel, there was a connector to the door module that was not inserted properly by me (what a fool I am), that cleared all the codes mentioned above.
HOWEVER, I am STILL getting the Passenger Restraint Malfunction error on the iDrive. I am not able find a code on my reader, cleared all the codes present and it still did not clear the message on the iDrive. I had an issue with this many years ago, BMW dealership did a software update which solved the issue (believe it was part of a recall or service bulletin).
Any suggestions? The seat was not tampered with at all during this time.
