I have an electrical problem ... when the car is turned off and the light switch is turned off my right front low beam headlight and right tail light come on intermittently. If I turn the key on and or start the car they both turn off. So it is happening more often and i now have to disconnect the battery when the car is parked. One suggestion is that it is the ignition switch. Has anyone else had any experience with this?
RB
So I solved this with a new relay now installed in the fuse box... however now all the lights work except I do not have a turn signal. Ordered new relays for all other spots in the fuse box. They have not arrived yet but hoping this will solve the turn signal problem.
