Results 1 to 2 of 2
Thread: Did a cooling system on the 525
    Nov 2007
    Justin Texas
    2003 525it 2003 X5 4.6is
    I had a leaking radiator on the wagon.
    Ordered all the fixings to do it up.
    New hoses, thermostat, water pump, coolant tank,
    Aluminum water pump pulley, new temp sender,
    The whole 9 yards.
    It’s hot, and I have COVID, so it’s slow going.
    Most of the parts that came off were about 10
    years old. It had a metal water pump impeller. I would have
    reused it, but just started over. Wanting every drop out I managed
    to remove the block drain bolt. Other have said that if you are doing
    the water pump, that’s the same level as block drain .it’s not, a lot more
    Coolant came out. I let it drain overnight.
    I jacked up the nose and used a non BMW coolant.
    It’s still blue, so I’m sure it will be fine. I also stuck in
    a blue bottle of VP racing Cool down additive.
    Needle looks maybe a nano cooler? Might be sitting on my wallet wrong.
    Tried a different method of bleeding. Jacked nose way up. Turned key to
    accessories, put both cabin temperature at 90.
    That started the electric aux pump. As I filled up the coolant tank,
    It started pumping out fluid. I racked both brass bleeder screws, very
    Low bubbles or air. I did a test run, but will check it tomorrow
    after a cooldown.
    I will always own a BMW.
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    Nice work. Bleeding the air out of the radiator has always been a confusing procedure and everyone seems to have a slightly different approach. I find that bleeding over several days helps to get all the air out.
    Hope you're recovering well from COVID. I had it back in March of last year.
    Frankie
    Texas, USA
    frankies-bmw.com
  1. strange cooling system problem please help
    By cag k in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-09-2002, 11:17 AM
  2. Cooling system all $@%*ed UP! HELP!!!
    By Drifter-X in forum 1991 - 1999 (E36)
    Last Post: 09-24-2001, 10:44 AM
  3. Info on Cooling System Flush
    By Lone Star in forum 1991 - 1999 (E36)
    Last Post: 07-15-2001, 09:34 AM
  4. Strange cooling system problem, need help!
    By Stylin in forum 1992 - 1999 M3 (E36)
    Last Post: 06-04-2001, 12:21 PM
  5. Need help, Strange cooling system problem
    By Stylin in forum 1991 - 1999 (E36)
    Last Post: 06-02-2001, 04:00 AM
