THE TRANSMISSION GEAR LIGHT IS ON, WILL NOT SHIFT INTO GEAR WITHOUT MANUALLY RELEASING THE EMERGENCY LOCK UNDER THE SHIFTER, IN "D" IT IS CONSTANTLY STUCK IN ONE GEAR - 2ND OR 3RD (?). THERE IS A NOTABLE "KICK" WHEN SHIFTING THE LEVER FROM "P" TO "R" OR "D" POSITIONS. THE CAR DRIVES 20-30MPH WITHOUT ANY ABNORMAL NOISES. BATTERY DISCONNECT WAS ATTEMPTED, BUT IT DIDN'T HELP.
FAULTS STORED:
0x004E25 EGS: Electronic pressure control valve 6
0x00A112 CAS: 0x002F80 DME: Engine switch-off time, plausibility fault
0x002ADO No message from transmission control unit, receiver DME, transmitter EGS/SMG/DKG
EGS PRESSURE CONTROL FAULT IS CURRENT.
SHUNT CURRENT GREATER THAN THRESHOLD
What's this all mean? What's wrong and how to fix it? Is it safe to drive without inflicting any further damage?
Please, advise!
