Results 1 to 10 of 10
Thread: BMW F30 Cranking but not turning over
    Sep 2016
    West Chicago
    2013 BMW 328i Xdrive n20
    Hello, all it's been around five months since I last drove my f30. It stopped working after I replaced the valve cover. I tried many different solutions like a new vacuum pump battery recharge I checked all connections. I also replaced the high-pressure fuel pump with the newer version I got the car to start but it immediately stopped and back to square one of it not turning over. I'm starting to think it could be the Valvetronic actuator. Any tips/help would be appreciated I really don't want to junk or replace the engine.
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    Pull the codes. They may give you a clue as to where to start looking.
    Sep 2016
    West Chicago
    I'm getting pages of codes but when I look it up they tell me that the hpfp and vaccum pump can throw multiple codes which I have replaced the only thing I can think of is the valvetronic.
    Jul 2004
    Houston, TX
    36 Cylinders
    Cranking means engine spinning, which also means it's turning over.
    So the starter spins the engine fine, but it doesn't fire up?
    Also, the code list may help. But not P codes. BMW manufacturer codes
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Sep 2016
    West Chicago
    at this point I've been looking at replacing the cylinder head so I don't have to diagnose part by part but I'm going to get a BMW specific scanner so hopefully it can narrow down the problem.
    Sep 2016
    West Chicago
    Update: I got a better scanner that reads BMW-specific codes I reset all the codes and turned the ignition on and finally after months it turned over but it shut off after 5 seconds or less. The codes before I cleared it was telling me that there's a short in the circuit for the Valvetronic actuator, wastegate, and map sensor but after clearing it I'm getting codes:140301,140310.140401.140410
    These codes are misfires in cylinders 3 and 4 and it's telling me both cylinders' fuel injection is cut out.
    I know it's not the spark plugs or ignition coils since I replaced it about 10k miles ago.
    Jun 2012
    San Antonio, TX
    1995 BMW M3 Coupe
    Dis you accidentally swap coil wires for cylinders 3 and 4?
    Sep 2016
    West Chicago
    You know I looked at your comment and thought are you kidding me it's not that easy of a fix then I checked it out and it the wires looked right but I still decided to swap them for the heck of it. I turned the car on and it started right away. Finally after almost five months of the car just sitting there It started thank you for the help I would have never thought it could of been that simple of a mistake.
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by RBNetEngr View Post
    That was an oddly specific and targeted suggestion!
    Quote Originally Posted by shakmonster View Post
    This is great news. Glad the car is back and alive!
    -Abel
    Jun 2012
    San Antonio, TX
    1995 BMW M3 Coupe
    Glad to hear it was an easy fix. I had a similar issue on a non-BMW a few years ago, and got a similar code from the affected cylinders.
  1. E38 cranking but not turning over
    By jsaunders1209 in forum 1995 - 2001 (E38)
    Last Post: 05-24-2018, 06:11 AM
  2. E30 m50 swap cranking but not turning over
    By E30bruno in forum 1983 - 1991 (E30)
    Last Post: 05-16-2017, 10:45 PM
  3. BMW X5 2001, Key not turning car over.
    By zackdp in forum 1999 - 2006 (E46)
    Last Post: 12-09-2016, 11:50 AM
  4. BMW X5 2001, Key not turning car over.
    By zackdp in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-07-2016, 12:30 AM
  5. Replies: 6
    Last Post: 02-08-2015, 09:59 PM
