Thanks - I had read this with great interest - and to psych myself up and prepare for bleeding . . .
I should have been more clear in my question, but what is not obvious to me is whether everyone is removing the small segment of bent hard pipe between the slave and the hose upon reinstallation? With the hose small bent elbow screwing directly into the slave?
It seems that both the now-shipping OE hoses and the aftermarket hoses with the larger lumen to remove the “CDV” all have the same geometry with the small integral bent hard pipe - but nowhere near as long or bent as what is in the car now. Is there some engineering reason for this longer segment of hard pipe beyond navigating out of the tight confines between the slave and insulation? (While I have the Rogue rear shock mounts, I am often biased toward preserving original engineering when I don’t know better). If all are deleting the little hard pipe are you also not reinstalling the bracket (I am not sure how it would fit with the different geometry hoses)?
On the other topic of the pseudo CDV valve delete - I am sure the majority of the forum will say get rid of it pronto. I also assume this part was designed to avoid driveline stress (such as when added to Honda S2000) - albeit at cost of some additional clutch wear (although that wouldn’t explain the 3.0 version - maybe it really is just for bad manual drivers). I am not one to intentionally dump the clutch - but with the postulate that stresses on the diff hanger being key contributor to the subframe/trunk floor issue, do I really want to remove any potential safeguards?
