Results 1 to 9 of 9
Thread: Help me baseline (de-frankebstein my engine)
    Aug 2001
    Potomac MD
    2004 545i, 1995 Euro M5, 1999 740i, 1984 Euro 635
    Help requested from fellow 745i owners'
    I love my car! I love the way it drives but I really need to make sure that the engine bay is back to stock.
    My vacuum pump is always on and it seems to be connected improperly... There is a mysterious hose floating next to the vacuum pump .. my vents are stuck on defrost..
    My heater core has been disconnected
    Suspiciously looking wires on their last legs
    See for yourself.. I need help!!
    Please post clear pictures of your own engines.. and feel free to guide me.. with comments, recommendations. . Thank you in advance
    Aug 2001
    Potomac MD
    Quadratechtown, PA
    5, 7, 4x4
    You are going to need the Electrical Troubleshooting Manual for your car. Unfortunately, these are for the US cars but most of the wiring is the same US to €.
    Not owning a 745, I can only spot a couple issues. The brown wires on their last legs seem to be the fluid pressure and brake fluid level switches. They all make the brake light on the dash go on if there is a problem.
    Some cleaning and then some orderly refreshing of all the taped splices would be in order to move forward on this project.
    Aug 2001
    Potomac MD
    Indeed what I planned to do tomorrow
    Thank a lot. Cheers
    Aug 2001
    Potomac MD
    bump..
    745i owners. please post pictures of your engine bay....
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Heater core is bypassed.
    Unplug the aux vac pump.
    Valve cover to manifold braces missing.
    Missing atmo sensor by main relay.
    Wrong exp tank cap.
    Hydroboost pressure switches leak and so do the return lines.
    Household wire nut by battery and garbage wiring.
    Bad wiring at CTS and missing cover on distributor cap.
    Old fuel lines and leak prone fuel damper on inlet.
    Vacuum lines all in incorrect spots.
    No AFM cap
    All I caught in about 5min of looking.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Aug 2021
    Whitehall, Pa
    1984 733I
    It is unreal how similar this is to a 733I. the layout and pieces are nearly identical.
    The vacuum pump thing is super common. that will be a process to go through it all to get your HVAC working properly. There is lots of that info on the boards here. The best thing to do is unplug the pump until you can tackle that job. the pump will overheat and die and they are expensive.
    When you decide to tackle it I can send you some pictures of where everything is supposed to go.
    Aug 2001
    Potomac MD
    Quote Originally Posted by Hit Man X View Post
    YES unplugged. Getting a replacement one
    [B]Indeed. I am looking for one. Any pointers[/B]
    Please show pictures of a stock/normal 745i engine bay so that I can have a baseline. Where can I find this sensor? What is its main function
    Wrong exp tank cap.
    No wonder it leaks sometimes.
    [B]Please help me identify this by drawing on my pics or showing me pics of a properly sorted one.[/B]
    That's put mildly. I plan to REWIRE everything.
    Will replace.
    I need you guidance in getting this right
    No AFM cap
    QUESTION:
    Do I still need a Wastegate upgrade if I install an AEM electronic boost control?
    Thanks so much. Where do I go from here? Please see my comments/question inline.
    Quote Originally Posted by Feyrerm View Post
    I am ready indeed. THANKS IN ADVANCE for sending pics.
    Aug 2001
    Potomac MD
    Wrong exp tank cap.
    No AFM cap
    Hi all
    Just went to the forum postings about the 745s and realized that many of you are very familiar with this very car. This is "DaneSpann*'s Alaskan 745i. I am the happy current owner since 2020. I LOVE the car and plan to make us all proud and finish what Dane started.
    Cheers
    Next steps.
    1) Install the full Buffalo interior replacement that I acquired over a year ago.
    2) Fix the sagging rear SLS suspension which stopped working all of a sudden (2 weeks ago) and won't raise the car any longer at startup or when parked (as it always did). The only thing I did differently on the car was to have a mechanic flush the transmission fluid... (Shifts superbly)
    3) replace the front shock mounts (cracked). Got the part already.... but I might as well put new front shocks (I am not sure if these were recently replaced). I could not find brand new start mounts so I settled for kmac stage 2. Was that a mistake?
    4) put AEM electronic Boost controller (although I am hesitant and think it might be an overkill for a daily driver always operating for the most part to the limits of getting a ticket).
    ....Truth be told I am just looking for an excuse to have those 1
    Quad VDO gauges!!
    5) Paint it to its original AgateGreen/AchatGrün color
    6) install the already acquired BBS RC090 17x8.5 with 2inch front and 4inch rear lips.
    Wish me luck!!!
    Of course all of the above would be after sorting out the vacuum pump, wiring etc ..
    Cheers
  1. Help! Clicking Noise Coming From My Engine
    By GrkMf95M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-27-2003, 06:10 PM
  2. Need help Washing a 1.9L Z3 engine
    By jsp98m3 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-23-2003, 04:29 PM
  3. Help: Ticking noise from car when engine cold
    By Mike88 in forum 1991 - 1999 (E36)
    Last Post: 08-10-2003, 01:59 PM
  4. Help! Need your opinions for M3 engine mods
    By FLoSSeN20 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-26-2003, 02:48 PM
  5. Help. Installed UUC SSK and Check Engine Light Came On
    By meekay in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-26-2002, 05:55 PM
