Selling my RMS Stage 2 obd2 S/C kit, some back ground on this kit. I purchased it in 2016. It wasn't complete, I have spent some time piecing it together that year. Replaced with new tensioner from RMS along with some hardware, ,aftercooler pump harness , new injectors and rebuilt the supercharger unit at 928 Motorsports with new seals and bearings. The car dynoed 416hp/324tq on 93 octane at MaximumPsi on 11--12 psi with full AA exhaust header and m50 intake manifold (s52 engine). Dynoed following year with same HP at another dyno place, ,it has been super reliable and fun over the years. This was on a strictly summer car. I have put at most 7--8k miles on this setup after install. This is a full kit including MAF and software. All you will need that I would recommend is ARP headstuds at the bare minimum but at that point you might as well do a headgasket, I ran cut O-ringed stock compression one. Now to the list (Fuel pump not in the photos, still on the car, will remove shortly) I do have one of the dyno sessions on my instagran if anyone is interested to hear it let me know, Also attaching a flikr link with photos, hopefully it works. -- > https://flic.kr/s/aHBqjzUmGa
-V2 Vortech Si Supercharger
-8 Rib 3.33 S/C pulley with 6" 8 rib crank pulley rated for 11--12 psi
-RMS tensioner and brackets
-RMS Aftercooler with heat exchanger , pump and hoses and a harness already extended for desired location , wired with relay
-Porsche 803 MAF Sensor , bought new in 2016
-K&N Filter
-DME with RK Tunes
-42 LBs Injectors with new O-rings
-Bosch Diverter Valve
-Braided oil feed line and rubber drain line
-Walboro GSS342 Fuel pump (bought new last summer from maximumpsi)
-I do have a new single spal fan (30100400) I never used I can throw in
The bad - nothing major
Check photo that I'm pointing to with screw driver, alen bit apears to be broke and stuck in that one bolt to the bracket
from previous owner. I never removed it because you do not need to separate the bracket or remove those bolts for the install.
Asking 4500$ trying to avoid shipping as it would cost a fortune, would prefer selling locally but will consider shipping at buyers expense. Located in Northern NJ , any questions or need more pictures, please PM me, thanks
added photo of the fuel pump
sale pending
sold
