Hi,
I've got the following fault codes on my 2003 525i Touring with 146k miles: P0313, P0171 and P0174. I have been trying to diagnose it by replacing the vacuum tubes in the engine bay, new valve cover, replacing the CCV system, new intake boots, New DISA o-ring as well as new o-ring for the oil dip stick. Also, I've ran a smoke test without finding any leaks as well as cleaned the MAF with CRC air sensor cleaner.
One additional thing that may or may not be relevant is that i removed the entire intake during the CCV replacement, and I am not entirely sure I had the P0313 code before doing that. There doesn't seem to be any leaks though as the re-install went smoothly and everything fit together without forcing it.
Does anyone have a clue on what might be the reson for the fault codes?
Thanks.
I just replaced everything hoses gaskets etc. now when I start my car it won’t idle it just dies it will run if I Revit up if I step on the brake pedal the car instantly dies any suggestions what the problem could be
Current Garage Highlights
2003 525iT TiSilver
2002 M5 TiSilver
Former Garage Highlights
2005 X5 4.8is
2004 325iTs (2x)
1973 Pantera L
1969 Road Runner 383
