Results 1 to 2 of 2
Thread: 2003 Z4 3.0i 6 speed manual with 80K on the clock time to replace the clutch?
    Southern NH
    535 E28 + E95 Z4 3.0i
    I have a 2003 Z4 3.0i 6 speed manual with 80K on the clock, the clutch is biting at the very top and with ¼ to ½ depression of the peddle the clutch slips. Is it time to replace the clutch? Where did you have it done and how much did it cost? (I’m in southern NH) Did you replace the Mass flywheel at the same time? I believe it’s a 3 hour job!
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Does the clutch slip when driving at low rpm and high throttle? That’s what would make me suspect a bad clutch. I think pedal position is designed not to change as clutch wears. 80k miles doesn’t seem like a lot. Have you ever flushed the brake fluid? If not I would start there, being sure to bleed the clutch slave.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
  1. Z4 E85,E86 FS: 2003 Z4 3.0i Silver/Black 6-speed SoCal
    By beemwe in forum 3 series & Z Series
    Last Post: 09-26-2012, 12:29 AM
  2. WTB: 2003-2006, z4 'vert, 6 speed manual
    By Mawgie in forum 3 series & Z Series
    Last Post: 07-23-2011, 10:24 AM
  3. Z4 E85,E86 FS: 2003 Z4 3.0i Manual (NJ)
    By nickpapa in forum 3 series & Z Series
    Last Post: 02-03-2011, 02:04 PM
  4. Z4 E85,E86 2003 Z4 3.0i 6 Speed with every option Sterling Gray/Black $15,500
    By Mooseiah in forum 3 series & Z Series
    Last Post: 05-29-2010, 12:18 AM
  5. FS: 2003 Z4 3.0i 6 Speed Roadster with every option Sterling Grey/Black $15,500
    By Mooseiah in forum Georgia sponsored by Harrison Motorsports
    Last Post: 05-28-2010, 01:18 PM
