Hey guys I’m here once again lol BMW life. I was driving home one day and the car went nutz. It shutoff while driving went into N and the on board messages were Drivetrain Malfunction & Starter/Ignition with a check engine light. I towed home on dolly’s. I changed the starter myself. The new starter does one click very loud. And there is a hum sound both from engine bay. I ran the codes with My code reader before and after the starter being changed. Those codes looked nuts so I went to autozone and I have these Power train system codes as following:
P169F: Throttle Valve Limo home mode Active (Bank 1)
P110D: Throttle Position Sensor A and B Circuit Range/performance (Bank 1)
P0123: Throttle/pedal position sensor A circuit High Input
P0222: Throttle/pedal position sensor B circuit low input
P:0238 Turbo/Super Charger Boost sensor A circuit High
P0108: Manifold absolute pressure/Baro sensor high input
P007D: Charge Air cooler temperature sensor Circuit high Bank 1
U019F: Lost communication with engine coolant pump control module.
Anyone have any ideas before I take it to a speciality shop 😭
See if you can turn the motor over by hand with the transmission in neutral.
I for one don't really trust "P" codes, for they tend to be a bit misleading.
The other thing is you can get a lot of codes, but they are not the primary issue, so clear all codes and see which one comes back.
Darin
Current:
Past:
79 525 euro Green/Green RIP
M-Flight Member
If your battery needs replacing, you can also get lots of unrelated codes and warning messages.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
The P codes are the most recent codes I cleared with Veapeek obdII. Transmission is in P will not move with the Tectronic lever (stuck in park) I can upload the reads with dates. However the battery has had a couple discharged messages since car has been not started. However the battery is pretty new got it at around 65k itÂ’s 900cca Die hard battery AGM from an auto store. 12v. How would I turn the N55 motor over by hand ? ItÂ’s a 15 435i gran coupe. There was a lil smoke and a rubbery burning smell when the car shut itself off.
Would this be the key Fob battery causing these issues or the main battery in the trunk. Car is fairly new. I only have 79k. Don’t know previous maintenance but have preformed an oil change I also need to change my oil level sensor.
The point was that P codes are vague when compared to BMW manufacturer codes, which you should be reading instead.
This is not a car that you can service with AutoZone. If all you have is a phone, then get Bimmerlink to read codes.
You can also do some functions through it. For example, when the battery was changed, it should have been registered as exchanged.
For what it's worth, the battery can be new, and the alternator not working and cause the same. Or is your accessory belt even present to spin it (smelling rubbery?)...
It may have to go to a shop.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
Date: 6/6/22, 8:24 PM
VIN: WBA4B1C50FG241448
06 Allround-view camera
1 error
800B9F: Undervoltage detected
10 Central gateway module
1 error
801C20: Central fault memory full
12 Motor electronics
11 errors
107A50: Throttle valve: emergency operation active
100A04: Throttle valve, throttle valve potentiometers 1 and 2: double fault
101001: Throttle valve, throttle valve potentiometer 1, electrical: short circuit to positive 101202: Throttle valve, throttle valve potentiometer 2, electrical: short circuit to ground 121001: Boost pressure sensor, electrical: short circuit to positive
104401: Absolute pressure sensor, intake manifold, electrical: short circuit to positive 108A01: Charge air temperature sensor, electrical: short circuit to positive
CD9010: LIN, communication (engine coolant pump): missing
CD8E12: LIN, communication (generator): missing
1C4119: Engine oil temperature sensor, electrical: malfunction
201004: CBS client: output of substitute value
1C Integrated chassis management
1 error
D02D58: Signal error (wheel torque drive 1, ID: WMOM_DRV_1) - qualifier
30 Electric steering lock
1 error
482394: Sensor - rotor position - steering angle - loss of multiturn value
37 Amplifier
1 error
B7F4E0: Logic part: Undervoltage detected
40 Car access system
9 errors
030484: Steering wheel electronics (LRE), steering wheel vibration: voltage outside valid range
8040B5: Engine start error during starter operation: No speed when activated 8040B9: Deactivation of terminal 30B: OSFG reached
8040BB: Kl30B active: start capability limit reached or Kl. 30B active for a long time 8040BD: Terminal 30F reset or shutdown
8042DF: Interior light unit (ILE): Interior light at the back. Bulb defective or wire break 804398: AUC sensor: short circuit to positive or open circuit
2
804399: AUC sensor: Invalid PWM signal 80444D: Inside mirror: undervoltage detected
60 Instrument panel
1 error
B7F668: COMBI: system time was reset
67 Controller
1 error
E2EC08: Signal (0x330) received invalid: Distance_km
72 Driver's side footwell module
2 errors
8031D4: Sensor supply voltage: short circuit to minus 8031D9: On-board voltage too low
78 Automatic heating and air conditioning
2 errors
E71470: Message (ST_CHGINTF, 0x3B4, FA): Timeout E71472: Message (CHGNG_ST, 0x3E9, FA): Timeout
Info memory
Date: 6/6/22, 8:28 PM
01 Airbag
2 errors
010002: Speed - signal incorrect
C95423: ICM: Front axle steering angle effective - signal invalid
0D Tailgate function module
1 error
0D9312: SG reset detected
8 errors
1011FF: Logger error memory entry for other ZGW components
101008: Non-resolvable ambiguous routing - SG not in the SVT target table 101010: SIF error
101012: TM Error
100600: Flexray protocol startup time is too high
100104: HW Weckgrund ZGW
100203: DM software error info warning
100204: Message monitoring: no system context signal
5 errors
121521: Boost pressure sensor: group error
104B01: Absolute pressure sensor, intake manifold: group error 108930: Charge air temperature sensor: group error
108920: Charge air temperature sensor: group error
231501: Error memory entry: Send buffer full
17 Electronic fuel pump control module
1 error
481B15: KL30 reset
2 errors
48276E: Autosar - StandardCore - Non-Volatile Memory - Integrity failed 4827B3: Internal control unit - Undervoltage at Terminal 30
29 Dynamic stability control MK60 E5
1 error
4809C0: Local power supply - control unit reset
2 errors
482451: Sensor - rotor position - steering angle - loss of multiturn value 2
300304: DEM_EVENT_RTC_NOTIFY_POWERLOSS
37 Amplifier
1 error
930001: Supply voltage: minimum value undershot
3 errors
804001: Reset due to start-up 804002: Reset by external 804029: NVM_QUEUE_EEPROM
41 Headlight driver module, left
1 error
410006: reset
42 Headlight driver module, right
1 error
420006: reset
56 Roof function centre
2 errors
801A0E: NVM_E_INTEGRITY_FAILED 801A1C: LINIF_E_RESPONSE
3
5D Camera-based driver assist system
1 error
5D0038: Qualifier error
60 Instrument panel
2 errors
93000A: FBlock with method: Sign of life does not arrive on time 930041: Function block: does not send any values despite notification
61 Combox emergency call
7 errors
610019: NVM integrity check failed
E14406: CAN message timeout GPS_PO_EXTS_MOST
E1442B: Invalid signal in CAN message POWERMGMT_CTR_COS E1442C: Invalid signal in CAN message STAT_ZV_KLAPPEN E14431: Invalid signal in CAN message V_VEH
E14413: Timeout of CAN message STAT_GANG_RUECKWAERTS E14414: CAN message STAT_ZV_KLAPPEN exceeded time
63 Headunit/radio
1 error
930001: Supply voltage: minimum value undershot 4
3 errors
E59418: CAN message, vehicle status (FZZSTD): Invalid signals
E5941E: CAN message, mileage range (KILOMETERSTAND): Invalid signals E5943C: CAN message, status radio key (STAT_FUNKSCHLUESSEL): Invalid signals
3 errors
078022: Message (vehicle status, 0x3A0) is missing 07802B: COMM_E_NET_START_IND_CHANNEL_0 078042: IPDUM_E_TRANSMIT_FAILED
5
Error memory
1 error
1 error
11 errors
1 error
1 error
37 Amplifier
1 error
9 errors
2
60 Instrument panel
1 error
67 Controller
1 error
2 errors
2 errors
3
All belts are fine. No suspected damage. Those codes are after I changed the Starter. However the codes previous looks different which I will post with dates
Error memory
Date: 5/14/22, 9:59 AM
01 Airbag
2 errors
930AC9: ODS system: passenger seat occupancy mat: sends CIS-internal electronics error (external comparator)
930BB9: Error memory locked
3 errors
CD0487: Synchronization process failed, CC was not yet synchronized when the error memory lock was released
801C15: Failed to fall asleep at 30B 801C20: Central fault memory full
11 errors
1C4119: Engine oil temperature sensor, electrical: malfunction 201004: CBS client: output of substitute value
101F01: Throttle valve angle - absolute pressure intake manifold, comparison: pressure too high
140001: Misfiring, multiple cylinders: Injection is switched off 140501: Misfire, cylinder 5: Injection is switched off
140201: Misfire, cylinder 2: Injection is switched off
11A002: High fuel pressure, plausibility: pressure too low
11A031: Low fuel pressure system, electric fuel pump: pressure too low 190F08: Tank ventilation system: malfunction
1C4110: Oil condition sensor: malfunction
213A21: On-board power supply voltage, working range: voltage too low
2 errors
480113: Dynamic Traction Control button - deactivates handbag function 480134: SBS function - direction of travel unsafe with vx greater than 2 m / s
37 Amplifier
1 error
12 errors
804080: Ignition on: startability endangered
8040B5: Engine start error during starter operation: No speed when activated 8040B7: Deactivation of terminal 15: OSFG reached
8040BB: Kl30B active: start capability limit reached or Kl. 30B active for a long time 2
8041A8: Welcome Light repeat lock active
3
Info memory
Date: 5/14/22, 10:01 AM VIN: WBA4B1C50FG241448
01 Airbag
3 errors
C95423: ICM: Front axle steering angle effective - signal invalid 010036: Info NoAlive MVBAT (KL30B)
1 error
060013: DM_EVENT_ZEITBOTSCHAFTTIMEOUT
16 errors
1000FF: VCM Logger error memory entry
100CFF: CAN logger error memory entry
1006FF: FlexRay Logger error memory entry
101012: TM Error
100601: Unexpected asynchronous state on Flexraybus 100100: Contact to FZM slave lost
100101: Sleep confirmations are not complete
100300: Commissioning could not be carried out because TAS is already busy
100001: VcmResultSvtCheck - identity check: Differences between the SVT actual and SVT target have been recognized.
5 errors
1FB601: Check control message (ID 450): Auto Start Stop function deactivated 231501: Error memory entry: Send buffer full
21A023: Combustion engine: false start or engine stopped without driver influence 1FB101: Power management: Battery falls below upper startability limit
1 error
481B1D: DM time message timeout
18 Transmission control
2 errors
2
420801: Shift-By-Wire: Info counter for Auto-P when leaving the vehicle 421732: Shift-By-Wire: Info counter for Hold-N
10 errors
480115: Driving dynamics switch - forced activation DSC
48279A: HSR function - Automatic activation of DSC on HSR function errors
03081F: FAS - front protection - acute warning triggered
48260D: Driving condition observer (FZB) - VCH at upper learning limit
482653: Slip angle estimator - restricted Model validity
482651: Slip angle estimator - inputs not valid SBS
48278A: SBS function - Lateral acceleration sensor - Error amplitude on the useful lateral acceleration signal due to suspected error ay
4827A0: SBS function - roll rate - error amplitude due to suspected error
7 errors
482451: Sensor - rotor position - steering angle - loss of multiturn value 300304: DEM_EVENT_RTC_NOTIFY_POWERLOSS
300206: DEM_EVENT_SCO_GLOB_UNDERVOLTGE_INT
300471: DEM_EVENT_SCO_UNDERVOLTAGE
300363: DEM_EVENT_WDPD_D2102_MC_IO_UNDERVOLTAGE_ERROR 3
4823CF: Diagnostic Master Queue Deleted
300207: DEM_EVENT_SCO_GLOB_UNDERVOLTAGE_EXT
35 Touchbox
4 errors
8BAC08: CANIF_E_STOPPED
8BAC09: CANNM_E_CANIF_TRANSMIT_ERROR
00001B: CANNM_E_NETWORK_TIMEOUT
8BAC40: Signal (Zeit_Sekunde_Zaehler_Relativ, 0x328): invalid
37 Amplifier
3 errors
930002: Transmitter / receiver module (FOT): temperature exceeds threshold 1 930003: Transmitter Receiver Module (FOT): Temperature exceeds threshold 2 930001: Supply voltage: minimum value undershot
3F Active sound design
1 error
3F100A: Signal (Zeit_Sekunde_Zaehler_Relativ, 0x328): invalid
6 errors
804000: Reset for unknown reason 804001: Reset due to start-up
4
8040CB: Terminal 15 shutdown via timeout
8041AC: Emergency light operation active through dropout of terminal 15
3 errors
410006: reset
410010: Stepper motor driver headlight range control: Cold-Warning (warning) 410300: Signal (Zeit_Sekunde_Zaehler_Relativ, 0x328): invalid
4 errors
420006: reset
420010: Stepper motor driver headlight range control: Cold-Warning (warning) 420011: Stepper motor driver cornering light: Cold Warning
420300: Signal (Zeit_Sekunde_Zaehler_Relativ, 0x328): invalid
3 errors
801A0E: NVM_E_INTEGRITY_FAILED 801A20: CAN_E_TIMEOUT
030221: SHD: Manual initialization process
5
5E Gear selector switch
2 errors
5E2696: Backup undervoltage detected 5E0005: Reset recognized
60 Instrument panel
7 errors
930006: MOST: Light goes out unexpectedly
E12C2F: Interface HU (acknowledgment request combination, 0x172): signal faulty E12C3C: Interface DME, DDE (status of engine fuel consumption, 0x2C4): Signal invalid B7F757: CBS reset detected
11 errors
E14405: CAN message timeout GPS_CTI_MOST
E14406: CAN message timeout GPS_PO_EXTS_MOST E14409: CAN message timeout TERMINALS
E14411: CAN message V_VEH timed out
E14426: Invalid signal in CAN message GPS_PO_EXTS_MOST
E1442B: Invalid signal in CAN message POWERMGMT_CTR_COS 6
E1442C: Invalid signal in CAN message STAT_ZV_KLAPPEN E14413: Timeout of CAN message STAT_GANG_RUECKWAERTS E14414: CAN message STAT_ZV_KLAPPEN exceeded time E14437: Invalid signal in CAN message GPS_PO_MOST
63 Headunit/radio
3 errors
101715: Positioning over 10 minutes not possible
101721: USB connection between head unit and TCB: No response to ping 930001: Supply voltage: minimum value undershot
67 Controller
1 error
790007: Signal (Zeit_Sekunde_Zaehler_Relativ, 0x328): invalid
10 errors
803296: RVC active without activation
8032B5: Ultrasonic sensor, rear outer left: acoustic or electromagnetic interference 8032D5: Front outer left ultrasonic sensor: acoustic or electromagnetic interference 8032DD: Ultrasonic sensor front center left: acoustic or electromagnetic interference 8032E5: Front center right ultrasonic sensor: acoustic or electromagnetic interference 8032ED: Ultrasonic sensor front outside right: acoustic or electromagnetic interference
804824: Outgoing error message buffer is full 7
8049FF: CANIF_E_STOPPED
E59467: CAN message, ZV and flap status (STAT_ZV_KLAPPEN): Invalid signals
3 errors
8
You can turn the motor over at the crank bolt, normally 27mm or so.
As for getting it out of Park:
Electronically releasing the parking lock
- Switch the ignition on.
- Apply the brake pedal and hold it down during the entire procedure.
- Press start/stop button.
- As soon as the starter can be heard to operate (this may take several seconds on diesel engines or at low temperatures).
- Press and hold down the release button (1)
- The specified time must necessarily be complied with!
- Push selector lever (2) forward up to point of resistance and hold for 2 seconds.
- Release the selector lever and quickly move it forward by another level again.
- The selector lever position N is displayed in the instrument cluster.
- The parking lock is now electronically unlocked.
- Release the brake pedal after the parking lock has been successfully unlocked.
- Leave the ignition switched on in order to subsequently move the vehicle.
- The transmission automatically shifts into P when the ignition is turned off.
Important!
The parking lock is reactivated without a message when the start/stop button is pressed again.
If the gearbox cannot be released, turn the ignition off and on again and repeat the previous steps.
Allow the starter to cool down for approx. 10 minutes after unsuccessful attempts.
Darin
Current:
Past:
M-Flight Member
