Bought the Spyder Halo headlight replacement
still deciding on using the halos for daytime running lights
know I need to tie into a fuse. Which number fuse should I use
Sorry should have said 1999 Z3 M roadster
one easy solution is to wire the halos into the stock turn signal bulb wire harness - it has a ground, a running light wire, and a turn signal wire. This way the lights will be wired to the headlight switch with minimal effort
