2014 328i xdrive
First BMW and getting used to all the different configurations as compared to cars here in the US.
May be a silly question, but I have a spring in the oil filter housing but when I watch videos of oil changes it just change the two rubber gaskets and off you go with the new filter.
Is there suppose to be a spring? Where does it go in relation to the filter? The one in there is curved slightly....any insight/advice would be greatly appreciated.
Realoem.com doesn't show any springs...
https://www.realoem.com/bmw/enUS/sho...diagId=11_5134
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
OK so the spring is actually meant to be in the cage? I thought that might be the case because some of the pictures I have seen seem to show a spring in the cage.
Thanks!
good diagram....but it doesnt show the cage housing that goes through the filter. I learned that inside the cage there is a spring.
If you go to realoem.com and enter the last 7 of your VIN, you can get the BMW part number of the cap for your specific car.
There will be a groove that the large o-ring will sit in, just pay attention to the old one. Normally it goes at the top of the threads, that way it will seal inside the canister.
Also that spring is part of the anti-drain back to keep oil inside the filter, if it's pooped loose then you will need a new cap.
Darin
Current:
Past:
79 525 euro Green/Green RIP
M-Flight Member
