Results 1 to 5 of 5
Thread: Rear spring dimensions?
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Does anyone have dimensions for any E23 rear springs, stock or aftermarket designed to fit stock hardware? Any of the following would be helpful: free length to within 5mm, coil outer diameter to within 2mm, wire diameter to within 0.1mm, coil count to within a quarter coil.
    Jun 2018
    MT View, HI
    98 318ti, 80 733, 76 '02
    I ain't going to be much help except to ask for more info for the knowledge base here.
    When I was shopping lowering springs, it made a ton of difference whether your 7 is an early or facelift ride. I forget the dividing year, but post up, our peeps here ought to know..
    Mar 2012
    Stateline/Lake Tahoe, NV
    1983 733i, 2011 X5
    I did a lot of research and couldn’t find a definitive answer by year —you have to measure. My ‘83 733i had 174mm front/114 rears. Realoem part numbers were the same for all as I recall. If you are looking for H&R springs in the US try these folks. Shipping was 100 euros. https://www.fahrwerk-24.de/H-R-Sport...mm_39#filtered
    SD, Cali, USA
    1995 M3, 1985 745i , S13 240sx sr20det
    I posted multiple threads with detailed info about all the various oem and aftermarket options for springs, was probably over ten years ago but you should be able to find it if you search. IIRC according to etk there was like 3 possible mm ID for front springs and 2 possible mm ID for rears. I have gone through multiple oem and aftermarket spring sets back in the day and all of them were the same ID measurements. I can't recall off the top of my head what they were though.
    95 BMW M3 Alpine-
    <GO...JIC Cross Coilovers- UUC RCAB, AKG FCAB, Rogue Engineering TM bushings- AA Gen3 Exhaust- Dinan F&R Strut Bars- Dinan F&R Sway Bars- X-Brace- Mishimoto Rad- BBS RK 17x8"- TRM Chip- Dinan BBTB- DIY CAI- JP Performance Headers- 21.5 injectors- JB Racing Flywheel- Bimmerworld TB boot- 540i MAF><SHOW...OE euro clear exterior lights- Depo w/ HID- Hurricane Alcantara interior- Stereo (Kenwood,Sony,MB Quart,Rockford Fosgate,JL Audio)- Black kidneys- Euro 3 Spoke- ZHP Knob- AutoDim Mirror>
    moroza's Avatar
    BFE
    E34T
    Quote Originally Posted by CMG View Post
    I searched extensively, can't find it anywhere...
  1. Info request: E32 rear spring dimensions
    By moroza in forum 1988 - 1994 (E32)
    Last Post: 05-11-2020, 09:33 PM
  2. Info request: 540iA rear spring dimensions
    By moroza in forum 1988 - 1996 (E34)
    Last Post: 05-09-2020, 05:05 PM
  3. rear spring dimensions for e28/e24. 1000 in lb source?
    By 1SIKSIX in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 12-13-2013, 10:14 AM
  4. Replies: 3
    Last Post: 05-09-2011, 01:56 AM
  5. E32 rear spring dimensions?
    By sfgearhead in forum 1988 - 1994 (E32)
    Last Post: 06-04-2010, 05:43 PM
