Results 1 to 6 of 6
Thread: anyone have a source - schematic diagrams for instrument cluster electronics E36
    Apr 2012
    ny
    1998 328i
    328i
    im having intemittent flashes of warning lights.
    sometimes the engine temp dial goes to 0.
    no problems with LED mileage display.
    thanks
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    from 6211.0 instrument cluster, all details http://wedophones.com/Manuals/BMW/19...g%20Manual.pdf
    Apr 2012
    ny
    1998 328i
    i have that manual.
    Was look for the schematic diagram for the instrument cluster itself
    i guess that is an internal BMW document
    Dec 2016
    Cambridge, MA
    1993 BMW 325is, 1997 328
    Quote Originally Posted by enf1945 View Post
    i have that manual.
    Did you ever manage to track down an actual schematic for your cluster? I just pulled one out of my E36 that died a slow death until it caused all kinds of crazy side effects. One obvious problem is a smoked SMD resistor near a 12v pin on connector A. It's apparently part of a simple voltage divider that sets the reference voltage for door microswitches and the Alpine alarm/remote system...
    Schematic would be a rarity! May sacrifice an all together different cluster to determine how to best strip the conformal coating from components and beige paint from the back of the PC board. If I get anywhere I'll drop the learnings back here.
    Apr 2012
    ny
    1998 328i
    use a flat razor blade to take off the coating . be careful not to hit the component, or to cut yourself
    Oct 2015
    AZ
    1998 BMW 740iL
    I see this thread was bumped a few days ago. I am taking a pass at repairing the cluster for my son's 318. The cluster was opened and all obvious things cleaned or re-soldered.
    While in there one thing looked wrong to me. There are a pair of transistors toward the top of the circuit board. Both have a heat sink attached. One is fine. The solder joints of the other look like the conformal coating has been hot or cooked a bit.
    The cluster failure was abrupt. The gauges just stopped working. All the other functions (lights, SI, odometer, etc) are fine.
    I am wondering if the transistor switches power to the gauges or some such. It would be nice to have a schematic to see what these transistors support in the cluster. I suppose they could be regulators. I haven't pulled the heat sink of to see the numbers for identification.
    *** time passes ***
    Heat sink is off. It is an ST BD437 low voltage transistor.
    *** time passes ***
    I changed out the transistor and verified the traces around it were ok. No improvement in the analog gauges but all the lights and checks seem to work now.
    -MO
  1. Wiring diagram for instrument cluster to bench test odometer?
    By alpinewhite318i in forum 1999 - 2006 (E46)
    Last Post: 03-06-2021, 10:31 PM
  2. Anyone have DIY on red lenses on instrument cluster
    By BMWslav in forum 1975 - 1983 (E21)
    Last Post: 01-17-2016, 06:24 PM
  3. Instrument cluster swap - E36
    By Geno325is in forum 1991 - 1999 (E36)
    Last Post: 01-21-2005, 10:14 AM
  4. Instrument cluster z3/e36
    By westcp in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-14-2004, 10:05 AM
  5. WTB: instrument cluster for e36 m3
    By steve m3 in forum BMW Parts Wanted
    Last Post: 08-19-2002, 07:01 PM
