Results 1 to 11 of 11
Thread: e36 No compression in cylinder 2
    May 2022
    Wentzville, MO
    1995 BMW 318ti Hatchback
    i have a 95 318ti and i had a bolt from an aftermarket throttle body get sucked into cylinder 2. i took the head of and there’s no damage to the wall but on the head you can see where it was hitting. cylinder walls nice and smooth, valves look a little crispy but are not bent, and the piston is looking good. you can see where to bolt hit and it got pretty close to valves so could it be the valve not sitting right?
    i also have a problem where when i plug my coil pack in my dash lights come on and yes the keys are not in the ignition.
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    If you had zero compression, the damage should be pretty obvious. The cylinder head might be cracked, or the valve bent and not closing properly, or even damage you're not seeing to the piston. Send the head to a good machine shop for pressure testing....or just find a used engine.
    Chris Powell
    BMWCCA 274412
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    +1
    M-42's are pretty stout little motors, but the smartest thing here would be just to replace the motor.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    NW suburban Chicago
    hiss by my window
    So, where is the bolt?
    It's pretty hard to imagine a bolt getting blown out the exhaust intact without having been caught between the valve head and the seat a few times.
    You are missing the damage.
    May 2022
    Wentzville, MO
    hey sorry for the late reply. i had a bent valve and bad piston rings. ripping the engine out and rebuilding soon
    Jun 2002
    E39M5, E500 4WD
    Reminds me of a coffee drink we had when I owned a restaurant. It was a double decaf nonfat latte. We called it "Why Bother"?
    You'll spend a lot less money, and a lot less time, if you just buy a used engine. Or, buy a BMW that has the other two cylinders.
    Chris Powell
    BMWCCA 274412
    May 2022
    Wentzville, MO
    believe it or not i tried looking for one but no luck. or if i do they want $1500-$2000 for it. it’d be cheaper to rebuild plus it’s a learning experience so
    dworthy's Avatar
    Nov 2010
    Understandable. 1995 was the last year of the M-42, for in 1996 OBD-II came into effect and so did the M-44 motor. Be sure to have the head decked and pressure checked for cracks, etc. I would be sure to replace the valve guide seals as you are going in that deep, oh and there is also a gasket that's a must to replace on that motor #10 here: https://www.realoem.com/bmw/enUS/sho...diagId=11_6003
    I am sure yours is leaking for you cannot replace it without pulling the head off to get to it.
    Fun Fact, the TI only had that motor for a very short time, something like a year before switching over to the M-44.
    Darin
    Current:
    Past:
    M-Flight Member
    May 2022
    Wentzville, MO
    i appreciate it. i will look into that and get it replaced. thanks again
    May 2022
    Wentzville, MO
    do you know where i can find torque specs for the engine?
    dworthy's Avatar
    Nov 2010
    In a Bentley shop manual? You can also spend about 30 bucks to get a 1 day to BMW TIS and download to your hearts content everything you might need.
    Darin
    Current:
    Past:
    M-Flight Member
  1. E36 e36 96-99 Master Cylinder | e36 m3 Slave
    By badluckM3 in forum Drivetrain & Transmission Parts
    Last Post: 03-14-2012, 07:36 AM
  2. E36 E36 M3 Brake Master Cylinder
    By RRdawho? in forum Engines, Performance Parts & Software
    Last Post: 09-24-2011, 01:41 AM
  3. E36 FS: Brand New FTE E36 M3 Clutch Slave Cylinder
    By vinnymac in forum Drivetrain & Transmission Parts
    Last Post: 06-20-2011, 01:03 PM
  4. E36 M52 for sale in PA: No compression in Cylinder 3
    By Pang85 in forum Engines, Performance Parts & Software
    Last Post: 06-21-2010, 02:00 PM
  5. E36 e36 M3 clutch master cylinder. Brand new, still in box, NEVER used!
    By Volf in forum Drivetrain & Transmission Parts
    Last Post: 12-30-2009, 06:38 PM
