Results 1 to 4 of 4
Thread: Thermostat gasket question
    Sep 2016
    Peekskill, NY
    1985 BMW 635CSi
    In the process of refreshing the cooling system parts and have removed the thermostat. I am looking at realoem and they show to assemble this actually without a paper gasket but just with an O-ring. I have always put this together with an O-ring and a paper gasket to go between the housing sandwiching the thermostat in the past... was I doing it wrong here? Is an O-ring all that is required? So thermostat just goes into the recessed area in the housing on the cylinder side right onto the metal, O-ring on top, and then the housing cover goes on that and 4 bolts torqued down? Is that sufficient to seal without the paper gasket between the metal surfaces of the housing and the cover? Thanks !
    My car is 6/85 635CSi.
    Feb 2022
    Sydney, Australia
    1986 635CSI (E24)
    The BMW Repair Manual stipulates a gasket
    North Carolina
    '86 M635/'10 Clubman
    Here's the RealOEM link for your car (though I assumed auto transmission, I doubt it makes a difference for the thermostat): https://www.realoem.com/bmw/enUS/par...E24-BMW-635CSi
    It looks like the right part might be 11531250399 but they've done some funky merging of the parts over time. FPC Euro thinks that's the right PN.
    https://www.fcpeuro.com/products/bmw...-11531250399oe
    The Vernet t-stat I put in the M635 came with both a gasket and an o-ring
    Relevant RealOEM page: https://www.realoem.com/bmw/enUS/sho...diagId=11_0690
    Sep 2016
    Peekskill, NY
    1985 BMW 635CSi
    Thanks, I saw that realoem page, it says aseembly without gasket... but yes Bentley does say assemble with gasket for some models... I guess I have a paper gasket on hand so I guess I will use that too...
    Oh, I see, by BMW repair manual, the factory manual? If so then with gasket it is then... thanks!
  1. Thermostat Gasket question
    By bamaboy473 in forum 1996 - 2003 (E39)
    Last Post: 04-29-2016, 07:58 AM
  2. M50 Thermostat housing gasket question
    By MadJeff in forum 1988 - 1996 (E34)
    Last Post: 08-31-2008, 07:54 PM
  3. Thermostat housing and gasket question???
    By Tralfaz in forum 1996 - 2003 (E39)
    Last Post: 07-24-2008, 10:38 PM
  4. Thermostat housing gasket question
    By mbogosia in forum 1992 - 1999 M3 (E36)
    Last Post: 12-27-2005, 12:09 PM
  5. Head Gasket questions
    By dgm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-08-2001, 05:47 PM
