Results 1 to 7 of 7
Thread: Completed M50 swap----rough idle...sometimes
    Oct 2014
    Ohio/Texas
    2 1999 M3's
    Just completed the bimmerworld m50 swap. When i fired her back up i got a real low/rough idle. Most of the time it bounces between 500-600 rpm sometimes dipping low enough to stall the vehicle.
    Now i did clean my IAC and throttle body out with carb cleaner. So i figured they might just need to relearn.
    Some times, like right this instant, it idles at a smooth 700-750 but will suddenly revert back to bunting betweeb 500-600.
    I double checked my 3 vacuum lines under the manifold. I got the bigger one thats attached to the solenoid thing attached to the icv connector. I got the other two smaller lines Teed into the manifold.
    Also the car run great, just idles funny.
    I pulled some codes.
    P0170 - FUEL TRIM BANK 1
    P0412 - SAP SWITCHING VALVE A CIRCUIT
    P0155 - O2 SENSOR HEATER CIRCUIT BANK 2 SENSOR 1
    P1188 - FUEL CONTROL (bank 1 sensor 1)
    P1189 - FUEL CONTROL (bank 2 sensor 1)
    Is the sap switcing valve the thing that plugs into the fuel injector wiring harness? (I drilled a hole through the manifold webbing in order to hook it back up)
    These fuel trim and fuel control codes have me thinking i may have switched the o2 sesnors on the intake manifold (even though i marked one sensor, it still has me thinking i did it wrong.)
    The other part of me thinks i have a faulty IAC thingy (or made it faulty by messing with it) and i want to replace it because i hear a buzzing wheb im low idling and the buzzing goes away when its smooth idling.
    I replaced the IAC hose because my old one was kinked but that did not help my idle.
    Now when i clear the codes the O2 sensor code comes back immediately
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    Carb cleaner is made for cleaning old fuel that turns to varnish and gums up carburetors. It is a very harsh cleaner. Brake cleaner would not be a good choice either.
    Throttle body cleaner would have been a better choice.
    [IMG][/IMG]
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    The swap isn't done correctly or you're not disclosing everything you did in the process.
    Feb 2009
    Arizona
    1998 e36
    M50 swap with OBD2 codes? Why is this in M3 section?
    Oct 2014
    Ohio/Texas
    2 1999 M3's
    The swap could be incorrect. I plan to pull everything out underneith it to double check everything. I think ill do it tomorrow.
    Because its on an M3
    Jan 2006
    Oakhurst, CA
    Quote Originally Posted by Gras rauchen View Post
    Hankentt is a known %#@*& idiot. Just ignore him.
    Oct 2014
    Ohio/Texas
    2 1999 M3's
    So the culprit was a split in the ccv hose. So sometimes it would leak. New hose and she idles smooooooth as butter
  1. M50 swap- rough idle and some other fun issues
    By QuinnClark in forum 1991 - 1999 (E36)
    Last Post: 06-21-2015, 05:34 PM
  2. E30 w/ S50 Swap - Rough Idle When WARM
    By nick325xit 5spd in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-23-2010, 04:15 PM
  3. FS: Bay Area COmplete M50 Swap and COmplete M3 Rear with Brakes Body Panels
    By precisioneffect in forum California sponsored by Avus Autosport
    Last Post: 12-26-2009, 05:59 PM
  4. E38 735i rough idle...sometimes
    By hammyh1970 in forum 1995 - 2001 (E38)
    Last Post: 06-08-2008, 04:31 AM
  5. Complete m50 swap
    By Stevefazek in forum 1983 - 1991 (E30)
    Last Post: 11-06-2005, 02:03 PM
