Great news!
Today I received a letter from BMW NA indicating that the emission warranty has been extended for the fuel tank, to 15 years/150k miles. This is to cover the issue with the top tank seal that fails, causing fuel vapor and/or liquid fuel to leak out.
Our 2014 F30 328i has this issue. If the fuel tank is filled, vapors will leak out of the tank and into the car, and you can even smell gas outside the car, outdoors.
The repair involves removing and replacing the gas tank. I’m so glad that it will be covered, because it’s a $2000 repair.
The letter also says that if you paid to get the tank repaired that they will reimburse you for the expense, provided you can show proof.
-rb
UPDATE:
I took the car to the local BMW dealership, and they replaced the gas tank, free of any charge. They even provided a loaner car for two days while the repair was being done.
Thanks for the heads up. Wonder if other variants of the F30 are also included.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
Well, I searched for the code listed in the letter from BMW (B-ELWR Fuel Tank EM15Y150M) and found this link:
https://dot.report/bulletins/10212779
There are quite a few models listed there other than the F30.
Thanks for the link.
is this issue only on 328i or other models also?
