Hey all,
I am having a bit of an issue. After my oil was changed, along with a new plastic plug and o-ring, I started to get some leaks coming from what I believe is the drain pan. It is a fairly slow leak but it is hard to pinpoint where it is coming from without setting the car on a vehicle lift and watching it for awhile. I believe the plug was a metal plug but it was recently changed to an OEM plastic plug that was torqued to 8ft-lbs (8Nm).
Has anyone experienced a similar issue when switching from a metal plug to a plastic plug? When I was under the vehicle I did not see any cracks in the pan nor did the female threads on the pan looked stripped. I am almost out of ideas as to where it is coming from and what might fix it. Do you guys know where I could find a good plug that meets spec? I am thinking it might be worth a shot finding a metal one again and seeing if that solves the problem. The vehicle is a 2014 528i (not an Xdrive).
Premium Guard Oil Filter, Extended Life Premium Guard5607EX| Fits BMW 2007-18 X5, 2007-13 328i, 2013-17 X3, 2012-16 328i, 2007-17 X3, 2007-15 335i, 2013-16 328i xDrive, 2009-13 328i xDrive
https://www.amazon.com/dp/B00VAFB4NQ...ing=UTF8&psc=1
This is the filter I used. I did not use the copper washer. Where does it even go?
Thanks,
