Results 1 to 2 of 2
Thread: BAD TRANS or VALVE BODY?? Gotta make a decision!!
    Jun 2021
    Atlanta
    2011 528i with NAV
    Bought a 2010 750Li with 131k miles knowing it has a bad transmission. First car wouldn't even go into gear. No fluid. I had mechanic change all the "mechatronics sleeves and refill with fresh fluid. Car now drives but it kicks you in the butt(on acceleration and deceleration) after a few shifts and goes into limp mode. My question is do I need a transmission or can I get away with just the valve body being rebuilt? I found a transmission I can pick up, but I have to make a decision while it's still available. Posting the Codes below. Bite the bullet on a Used Trans or go the cheaper route and re-do the valve body? Your input and suggestions are appreciated.
    CF1701 Message (All) For (EGS_EL,A-CAN, FA-CAN) From (GWS, A-CAN, FA-CAN) is missing
    1DB301 EGS, Signal Monitoring (Gear Information) Invalid Signal Content
    CF0400 Total malfunction of the CAN-Communication by line interruption
    400441 Ratio Monitoring Clutch E implausible
    400331 Clutch Monitoring 3-4 implausible
    401011 Collision backup measures with Equal Priority
    213901 Consumer Readuction: Active
    Jul 2012
    Dallas, TX
    2001 BMW 750il Sport
    I'm no expert, but I've dealt with a few transmission issues on BMWs. The loss of communication CF0400 concerns me. That's not caused by the valve body. I suspect you have a bad connector, wiring harness, or module.
    If this is the case, a new trans will not fix the issue.
    What are you using to pull the codes?
  1. E34 Looking for 540 auto tran valve body
    By ClarkWGriswold in forum E34 Classifieds (closing soon)
    Last Post: 01-24-2010, 02:57 PM
  2. E34 FS: IL 1994 525i 189K bad trans, body straight
    By Derek 350i in forum 5 series & 6 series
    Last Post: 01-09-2010, 07:44 PM
  3. 5 speed auto trans valve body from 740
    By palexand in forum 1988 - 1994 (E32)
    Last Post: 10-14-2009, 09:08 PM
  4. WTB 5HP30 Trans or Valve Body (w/ update)
    By 9mmkungfu in forum BMW Parts Wanted
    Last Post: 01-02-2009, 11:03 AM
  5. Need a trans valve body for test
    By dm635 in forum 1976 - 1989 (E24)
    Last Post: 06-15-2006, 08:23 AM
