Results 1 to 4 of 4
Thread: Question about the engine.
    May 2022
    Florida
    Cls550, soon Z4
    Greetings all, I am in the market for a z4 2009+, i really find these cars attractive and need a fun cat to drive. I currently own a CLS550. Love it, but I want a two seater manual. The more I research the Z the more I am starting to love.
    I would drive it alot, 300 miles per week probably.
    I am set on the 6 cylinder engine. Which one is more reliable?
    S30i? Or s35i?
    If you have any other suggestions or tips please let me know. Looking forward to being a long time member.
    Regards
    M.
    Mar 2005
    Bow, New Hampshire, USA
    2009 BMW Z4, Alpine Whit
    No matter which one you choose, change all the fluids, engine oil, transmission oil, power steering fluid, and even brake fluid. Check the top, for noises opening and closing, also time 22 seconds each way. Look along the interior of the top for oil stains. The top goes up and down using hydraulics, and a leaking hose means lots of trouble, and money for a repair. Also, in the top there are a lot of either Hall sensors, or microswitches. I would also change the two salmon colored relays located on the hydraulic motor block located in the trunk, just to the rear of the battery. These relays control the direction of the top motor for up, or down movement. They handle the full load of current, if the contact burn out you're either stuck with top up, top down, or mid way between. If the top gets stuck in the trunk, there is no emergency "up" but a trip to the dealer. The top must be up to change the relays. Notice in the battery area if water has pooled in there, that means a leak in the trunk seals, or roof seals. Best to clean all the seals on the top, recondition with gummy fludge, and lube all the tops hinges with spray lube. Good luck on your purchase of a E89 Z4
    May 2022
    Florida
    Cls550, soon Z4
    Thank you very much for the input will definitely do this.
    The N52 (30i) naturally aspirated 6 cylinder will be more reliable than the turbocharged versions (35i/35is). The N52 was only used for 2009-2011 "30i" models. It makes less power than the turbocharged 35i but it is still a lot of fun and is easier on gas too. It is IMO the best option if looking to be a long term owner of an E89
    PRICE CUT on ALL FABRICS
  1. Question about S54 engine problems
    By dave is cool in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-28-2003, 10:37 AM
  2. questions for mecanical engineers!
    By joe325i in forum Off-Topic
    Last Post: 03-18-2003, 11:49 PM
  3. Question about 325 engine
    By UD///M in forum 1983 - 1991 (E30)
    Last Post: 09-07-2002, 09:52 PM
  4. question about finishing engine swap, i need your help guys !
    By Dj Waffelz in forum 1991 - 1999 (E36)
    Last Post: 05-05-2002, 12:55 AM
  5. 2 questions with photos....engine
    By Brent_Vino in forum 1991 - 1999 (E36)
    Last Post: 04-09-2002, 01:33 PM
