Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 2 of 2
Thread: Offset Question
    Apr 2022
    Stittsville, ON, Canada
    2022 x3 30i
    Offset Question
    Hello all,
    I'm a newbie to the forum and also to BMW ownership.
    I have a 2022 X3 x Drive 30i and I was looking to buy a set of used 18" winter tires. I know I'm early but ss my Grampa once told me, the early bird gets the worm... but the 2nd mouse gets the cheese :-)
    So, to my question. I'm looking to buy rims and tires, I know the bolt pattern is 5x112 but when I've looked at different sites the specs for the offset vary from+20 to +45. What is the allowable offset I can use without using spacers?
    thanks,
    Jeff
    May 2022
    Phoenix,AZ,USA
    1986 535i, 1997 LX450
    additional wheel info
    I would assume you should match the offset of your OEM rims - so you are assured of no fitment problems at all, right? - unless you have a very specific reason to change it?
    You can almost always find the offset of your existing wheels by looking at the back side of the wheel spokes - usually cast in - like (ISxx) with xx in mm offset.
    The other wheel specifications that pretty much covers it:
    PCD Bolt Circle diameter.
    Center Bore diameter in mm.
    basic wheel size width x diameter - for example 8J x 18
  1. Wheel Offset Question
    By KingKongMMM in forum 1992 - 1999 M3 (E36)
    Last Post: 12-06-2002, 07:58 PM
  2. tire offset question
    By KingKongMMM in forum 1999 - 2006 (E46)
    Last Post: 12-05-2002, 07:30 PM
  3. E34 Wheel Offset Question
    By 95avusM3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 10-03-2002, 04:03 PM
  4. Wheel Offset question...
    By RUddin3 in forum 1991 - 1999 (E36)
    Last Post: 04-17-2002, 09:48 PM
  5. Quick wheel offset question... thks
    By TC3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 05-21-2001, 12:02 AM
