Originally Posted by
87155
Recently I have noticed that after I turn the car off there is a sound of leaking air from the left rear suspension (behind the tire) it can last for 5-10 minutes after the car is turned off. The car is not sagging and there are no warning lights. When you turn the car off the car does lower a bit in the rear, I assume this is the air suspension adjusting.
This sound has been there for a few weeks with with no sagging or warning light. last week the car was bottomed out and i took it to the dealer and they had the air suspension replaced (under warranty) after the fix the sound of leaking air went away temporarily however it has not come back.
The car has gone back to the dealer 2 times and they can not find any issue with the suspension or identify what the cause is.
Would appreciate any thoughts on what might be causing this sound
