Here's a little project I came up with after trying to keep my black plastic washer nozzles black. I would mask around them and apply some plastic conditioner but it was always a pain in the butt. The tape didn't stick well to the waxed surface and the effect would only last a few weeks. My solution was to paint the nozzles to match the car and that way they wouldn't need any special treatment while giving a cleaner look.
I started by buying a pair of new washer nozzles and then first sanding the pebbly texture smooth going from 280x to 400x to 600x dry-lube paper.
After sanding. I stuck push pins into the nozzle jets and packed the surrounding recess with "ticky tacky".
Next, I gave them a coat of primer. The brand I used works well with plastic but requires a full 5 days to cure or you will have issues when you apply a color coat.
After letting the primer cure, I thinned a bit of "Arctic Silber" touch-up paint with about 20% water (It was a waterborne paint) so that I could spray it with an airbrush. I found the paint was a much closer match when sprayed than when brushed on a touch-up.
Finally, after the color coat was dry, I applied two coats of automotive clear coat, again, using an airbrush.
I though it came out quite well. To be honest, I did get a couple of tiny dust nibs in the clear coat so I wet sanded using naphtha and 1200X followed by 2000X and then buffed on my buffing wheel. I'll post photos of them installed in the next post.
Here's a few photos of the installed nozzles.
I like the clean look. Someday, I'd like to delete the side markers on the bumper cover while I give it a much needed paint job.
Looks good, first time seeing that done.
Thanks. I've never seen it done before ether. I ordered an antenna delete plug. I'm not sure if the outer part of it is hard plastic but if it is, I may give it the same treatment.
Bravo - great idea for a winter project, and I'll order the antenna delete plug too.
Claude Berman, 96 Z3 Production Date 2/96 BMW CCA# 581686
The only good is knowledge and the only evil is ignorance. Socrates, 469–399 B.C.E
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
Neat! I go back and forth on those and the door handles - whether or not I'd prefer them body color. Fortunately they aren't super obnoxious on stahlgrau.
Nice. It reminds me a little bit of the chrome Z8 windshield nozzles people were putting on back in the day
PRICE CUT on ALL FABRICS
Thanks. Yeah it's one of those little details that is also fun and easy to do.
Yes, the color match was remarkably good. They look OE.
Thanks. Chrome might work with some colors but personally, I'm trying to not draw the eye to them.
I installed chrome door handle surrounds and find it's a little thing that really adds a lot of upscale class to the look. BTW, stahlgrau is probably my favorite color, especially with a burgundy and black interior.
Killer! I wouldn't mind chroming mine. I always wanted to chrome the nozzles & side mirrors (I recall Ron Stygar doing that back in the day) to get a bit of a Z8 vibe going. I do have OE Chrome Line windshield trim (uninstalled) and polished stainless roll hoops (installed), but I've learned the glass has to come out for a factory correct installation on the trim. Oh well, maybe someday.
Nathan in Denver
I once had a plastic cover on a motorcycle chromed and it came out really well and was not overly expensive. (about $75 back in 20011) I did all of the prep work myself. In my opinion, if you're going to chrome some items, try to have an overall image in your mind to keep a balance and a theme going.
Nathan in Denver
Excellent - why not do the whole car with Easy Chrome?
https://alsacorp.com/product/easy-chrome
Little pricey:
Is that Dan's Cobra?
Nathan in Denver
Lieutenant Dan?
I'm not sure whose car that is specifically. Shelby did a run of 50 "50th Anniversary" models which were available in this polished finish with brushed stripes. The cool thing is if you get a scratch you can polish it back out lol
Sorry, not trying to derail the thread...
Nathan in Denver
