Results 1 to 3 of 3
Thread: Water pump
    Lebanon
    E30 M3 S50B32
    Water pump
    Hey guys,
    just noticed my water pump is starting to have shaft play, will need to replace soon before it starts leaking. I'm just wondering, what is the deal with the water pump on the s50b32?
    I replaced this along with fan+clutch in mid-2016 but didnt drive the car much last 2 years, before that in 2013, and 2 pumps before that. So this will be pump #5 im installing during 16 years. They just dont seem to last more than a few years. Maybe aftermarket ones suck and i should get the OEM genuine bmw?
    I'm thinking about removing the clutch fan and putting a spal puller 2300cfm (is that enough alone?) in hopes that it'll reduce the loads on the pump's bearing and maybe they'll last longer.
    Appreciate any thoughts or insights.
    1987 BMW M3 S50B32 engine swap
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    That is unusual wear. On my 1998 US M3 I have now the 2nd water pump installed and that runs still fine since 2015. Shaft play can come from overtightened pulley/belt tensioner maybe
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Quote Originally Posted by liquidtension View Post
    I have a low mileage S50B32 and have not had an issue with water pump, but understand that they last forever compared to the S50/S52. OEM is spendy, but likely worth the investment.
    A well balanced engine driven fan isn't going to put much load on the pump bearing. You might be onto something... is the fan the original?
    Sat/Sun| 04M3 TiAg 69k slick-top 3 pedal
    Auto -X | 99M3 61k S50B32 284 euro 6Spd 3.91
    On The Market
    Project | 88M3 AW 43k miles
    Forum Rules
    New Member Info
  1. Finished up my water pump replacement...
    By dgm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-28-2002, 03:16 PM
  2. Had my 95 water pump changed...and...
    By BS05ZHP in forum 1992 - 1999 M3 (E36)
    Last Post: 05-07-2001, 07:44 PM
  3. Fuel filter/Water pump
    By Cock318 in forum 1991 - 1999 (E36)
    Last Post: 04-20-2001, 07:14 PM
  4. Water pump for 328..to change or not to change?
    By bob(NJ) in forum 1991 - 1999 (E36)
    Last Post: 03-20-2001, 11:48 PM
  5. thermostat and water pump went BOOM
    By Brett in forum 1991 - 1999 (E36)
    Last Post: 03-16-2001, 11:14 AM
