I don't see why not. I assume you have a lift if you are asking otherwise it would be quite a bit of work going in from the bottom on jack stands. I got my LS1 and T56 from a donor Camaro and removed it out the bottom without a lift and it was doable but not ideal. Dropping an LS1 mated to a Camaro t56 in from the top is doable with the Sikky swap oil pan and the hood and/or front bumper/nose panel removed. I can easily drop just the LS in with the hood on and the nose panel and bumper in place, but YMMV.
1999 E36 M3 Cosmo/Sand Beige LS1 swap
2022 G42 230i Thundernight/Tacora
